kq6up
- 368
- 13
Background: The problem is to find the uncertainty relationship for the wave equation for a delta function potential barrier where ##V(x)=\alpha\delta(x)##.
Check the uncertainty principle for the wave function in Equation 2.129 Hint: Calculating ##\left< p^2 \right> ## is tricky, because the derivative of ##\psi## has a step discontinuity at x=0. Use the result in Problem 2.24(b). Partial answer: ##\left< p^2 \right>=(\frac{m\alpha}{\hbar})^2 ##.
2.129 is ##\psi (x)=\frac{\sqrt{m\alpha}}{\hbar}e^{-m\alpha |x|/\hbar^2}##; ##E=-\frac{m\alpha ^2}{2\hbar^2}##.
2.24(b) Let ##\theta (x)## be the step function:
##\theta (x)=\left\{ 1,\quad if\quad x\quad >\quad 0.\quad 0,\quad if\quad x\quad <\quad 0. \right\} ##
(In the rare case where it actually matters, we define ##\theta(0)## to be 1/2.) Show that ##\frac{d\theta}{dx}=\delta(x)##.
I understand it up until the last step, and I even think I understand why it didn't work. I was able to integrate in steps for <x>,<x^2>, and <p>, but this does not work for <p^2>. I understand it has something to do with the step discontinuity that arises, but I guess I am having a hard time understanding why I had to integrate through the step on this one, but not have to include the point x=0 on the rest of them (I get the correct answer as well). The integrand is smooth for the integral determining <x>, and <x^2>. <p> has a kink, so <P^2> is discontinuous. In calculus up to this point I have always handled this by integrating over the smooth parts and adding the the sums of all the smooth parts. I am having trouble visualizing why I can't just assume the area under the curves of all the pieces are the only ones relevant, but that this point at x=0 adds so much info even though it is an infinitesimal contributor. I guess that is some of the weirdness that comes from making an infinitesimal point have an infinite height.
Thanks,
Chris
