RainmanAero
- 83
Greetings mega-brains!
A delta wing configuration, because it does not have a separation between the main wing and the horizontal tail which holds the pitch control surface(s), has a natural aerodynamic, temporary control reversal when initiating a pitch maneuver from a steady-state, trimmed, unaccelerated condition. In controls terminology this is called a "non-minimum phase zero".
What happens is this:
1) The generation of pitch rate via pitching moment lags behind the production of lift and drag.
2) As such, when you deflect the elevons upwards in order to cause a pitch-up, you initially spoil the lift-generation of the main wing before you have a chance to build up enough pitching moment to overcome the pitching moment of inertia.
3) This results in the flight path vector dipping downward (i.e. the plane falls), until sufficient angle of attack is generated to overcome pitch inertia and begin pitching the nose upward.
4) The opposite effect occurs when trying to pitch down (you initially lift upwards before you go down).
5) This is counter-intuitive (and somewhat alarming) to a pilot who is not aware of this natural aerodynamic tendency.
My question (and where I am looking for help, suggestions, and references) is this:
Short of the typical solution of adding a canard, which is deflected in opposition to the elevons to counter the initial loss of lift, is anyone familiar with any control system techniques that can minimize this tendency (with the hope of avoiding it) over the entire flight envelope.
I've heard "tribal knowledge rumors" about manipulating the apparent aircraft instantaneous center of rotation, but no one can give me details.
Gurus? What do you say? Many thanks in advance,
Rainman
Rainman
