MHB Demand for a certain Commodity
  • Thread starter Thread starter confusedbycalc
The demand for a certain commodity is represented by the function D(x) = 1000e^(-0.03x), and consumer expenditure is calculated as E(x) = xD(x). For part (a), the rate of change of consumer expenditure at a price of $160 is found to be approximately -31.27. To determine when consumer expenditure stops increasing, the derivative E'(x) must equal zero, indicating a transition from positive to negative values. The discussion also raises questions about the value of "e" in the context of the exponential function and the conditions under which E' becomes positive, signaling an increase in consumer expenditure.
confusedbycalc
D(x)  =  1000e−.03x
units per month when the market price is x dollars per unit.
(a) At what rate is the consumer expenditure E(x) = xD(x) changing with respect to price x when the price is equal to $160 dollars?
(b) At what price does consumer expenditure stop increasing and begin to decrease?
(c) At what price does the rate of consumer expenditure begin to increase?
I am not sure but I got -31.27 for a) but i really have no idea how to go about this question.
Mathematics news on Phys.org
D(x)  =  1000e−.03x
What is "e" here? (I suspect it is not 2.718...
With D(x)= 1000e- 0.3x, E(x)= 1000ex- 0.3x^2. The rate of change of that is the derivative E'(x)= 1000e- 0.6x.
As long as E' is positive the consumer expenditure is increasing. It is decreasing when E' is negative. To change from positive to negative, E' has to become 0.
when is E' positive?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
