Demo of cosine direction with curvilinear coordinates
In summary, the author discusses the dot product of a vector with Einstein notation in the context of curvilinear coordinates. The author states that ##\dfrac{\text{d}y^{i}}{\text{d}s}## represents the cosine directions and asks for a proof. In polar coordinates, the author asks for an expression of the 2 cosine directions using the 2 vectors of the curvilinear basis. The author also questions why the scalar product is not equal to ##\text{d}(v^{i}\dfrac{\text{d}y^{i}}{\text{d}s})## and expresses confusion between the cosine direction components and the angle ##\theta_i##. The author also asks for help
fab13
318
1) Firstly, in the context of a dot product with Einstein notation :
$$\text{d}(\vec{V}\cdot\vec{n} )=\text{d}(v_{i}\dfrac{\text{d}y^{i}}{\text{d}s})$$
with ##\vec{n}## representing the cosine directions vectors, ##v_{i}## the covariant components of ##\vec{V}## vector, ##y^{i}## the curvilinear coordinates and ##s## an affine parameter (it may be the length along the line, isn't it ?)
Author says that ##\dfrac{\text{d}y^{i}}{\text{d}s}## (with ##y^{i}## curvilinear coordinates) represent the cosine directions and I would like to prove it : how to do it ?
For example, in polar coordinates, How can I express the 2 cosine directions with the 2 vectors curvilinear basis ##\vec{e_{r}}## and ##\vec{e_{\theta}}## ?
On the following figure, I don't know exactly how to represent the vector ##\vec{n}## :
2) Secondly, if ##\dfrac{\text{d}y^{i}}{\text{d}s}## are cosine directions, why does above scalar product is not equal rather to :
$$\text{d}(\vec{V}\cdot\vec{n} )=\text{d}(v^{i}\dfrac{\text{d}y^{i}}{\text{d}s})$$
with ##v^{i}## the contravariant components of ##\vec{V}##. ?
Indeed,both (##v_{i}## and ##v^{i}##) are related by :
$$v_{i}=v^{i}\,\cos(\theta_i)$$ with ##\cos(\theta_i)## the cosine direction for the angle ##\theta_i## between ##\vec{V}## and ##\vec{n}## vectors.
I hope you will understand these 2 questions.
Any help is welcome, Thanks
Mathematics news on Phys.org
To try to answer your first question: ## \vec{r}=r \hat{a}_r ## in polar coordinates. But ## \hat{r}=r(\cos{\theta} \hat{i}+\sin{\theta} \hat{j} ) ## with ## \hat{a}_r=\cos{\theta} \hat{i}+\sin{\theta} \hat{j} ##. ## \\ ## This means, (by the chain rule for derivatives): ## \\ ## ## d \vec{r}=dr \, \hat{a}_r+r(-\sin{\theta} \hat{i}+\cos{\theta} \hat{j} )d \theta =dr \, \hat{a}_r+(r d \theta )\, \hat{a}_{\theta} ##, with ## \hat{a}_{\theta}=-\sin{\theta} \hat{i}+\cos{\theta} \hat{j} ##. ## \\ ## (Note that ## \hat{a}_r \cdot \hat{a}_{\theta}=0 ##). ## \\ ## Let ## d \vec{r}=d \vec{s} ##. Then ## ds=\sqrt{dr^2+(r d \theta)^2} ## and direction cosines are ## dr/ds ## and ## (r d\theta)/ds ##.
@Charles Link : Thanks for your answer. I would like to clarify a little problem : I don't know how we can define systematically the direction cosine ##\text{d}y^{i}/\text{d}s##.
Indeed, in the case of polar coordinates that we have taken here, the first direction is : ##\text{d}y^{i}/\text{d}s=\text{d}r/\text{d}s## , so we get the right matching ##y^{1}=r##.
But on the second direction cosine, I get from your answer : ##\text{d}y^{2}/\text{d}s=r\text{d}\theta/\text{d}s \neq \text{d}\theta/\text{d}s##, then we don't get the matching ##y^{2}=\theta##, i.e I have this second direction cosine equal to ##r\text{d}\theta/\text{d}s##.
How can I get rid off the factor ##r## between ##r\text{d}\theta/\text{d}s## and ##\text{d}\theta/\text{d}s## ??
Maybe If I start from the element : ##ds^{2}=g_{ij}\dfrac{\text{d}y^{i}}{\text{d}s}\dfrac{\text{d}y^{j}}{\text{d}s}##, I can define ##g_{11}=g_{rr}=\vec{e_{r}}\cdot\vec{e_{r}}=||\vec{e_{r}}||^{2}=1##
and ##g_{22}=g_{\theta\theta}=\vec{e_{\theta}}\cdot\vec{e_{\theta}}=||\vec{e_{\theta}}||^{2}=r^2##
Then, even with this convention, I couldn't get to have the expression of second direction cosine, equal to ##\text{d}y^{2}/\text{d}s=\text{d}\theta/\text{d}s## since :
If I express this second direction cosine : ##(\text{direction cosine})_{\theta}= \dfrac{\text{d}\vec{r}\cdot\vec{e_{\theta}}}{||\text{d}\vec{r}||\,||\vec{e_{\theta}}||} =\dfrac{\vec{e_{\theta}}\cdot\vec{e_{\theta}}\,\text{d}\theta}{r\text{d}s}=\dfrac{r^2\text{d}\theta}{r\text{d}s}=\dfrac{r\text{d}\theta}{\text{d}s}##
Unfortunately, I still obtain the factor ##r## which prevents to get ##\text{d}y^{i}/\text{d}s=(\text{direction cosine})_{i}##
If someone could help me to solve this little issue ...
I think the answer is that polar coordinates don't follow this simple formula because of problems with the metric. There are other people on this Physics Forums who know the details of that kind of mapping better than I do, but I think that is the conclusion that would be reached. Your additional calculations with the ## g_{11} ## etc. look like they are on the right track, but I am no expert on this topic. ## \\ ##@fresh_42 Perhaps you can add some expertise.
@fresh_42 Could you take a look please at my issue above or anybody else ?
Maybe should I put this post on another forum ?
The "General Math" section would likely get more people reading it. Perhaps @Orodruin and/or @StoneTemplePython might also be able to give an input. They both have very solid mathematics backgrounds.
ok, thanks, I move it from this forum
Likes Charles Link
The original post was on https://www.physicsforums.com/threads/demo-of-cosine-direction-with-curvilinear-coordinates.933583/
I know that (##v_{i}## and ##v^{i}##) are related by :
I think that I make confusion between the cosine direction components and the angle ##\theta_i##,
Any help is welcome
Following the answer of @Charles Link about the 2 questions above :
Likes Charles Link
The vector ##\vec n## seems to be the tangent vector of some curve, parametrised by its curve length ##s## such that ##\vec n \cdot \vec n = 1##. Its components are the direction cosines only if you use a basis that is orthonormal. When you are using a curvilinear coordinate system, this is not generally true when you use the coordinate bases. The inner product ##\vec n \cdot \vec V##, is an invariant that is always equal to the magnitude of ##\vec V## multiplied by the cosine of the angle between ##\vec V## and ##\vec n## (since ##\vec n## was normalised). For any two vectors ##\vec A## and ##\vec B##, the inner product can be written as ##\vec A \cdot \vec B = A_i B^i = A^i B_i##. Note that ##A_i B_i## as well as ##A^i B^i## are not invariants. In your special case, the contravariant components of ##\vec n## are ##n^i = dy^i/ds## (by definition of what a tangent vector is) and so to obtain the invariant ##\vec n \cdot \vec V## you must contract those components with the covariant components of ##\vec V##.
Note that ##dy^i/ds## is not a direction cosine, since the coordinate basis ##\vec E_i = \partial_i \vec x## is generally not orthonormal (in particular, ##\vec E_\theta## in polar coordinates is not normalised).
Likes Charles Link
I make confusions, for example in polar coordinates (##\rho,\theta##) , between the coordinate ##\theta## and the general equation of geodesics.
Indeed, following the expression of :
$$d\,\bigg(v_{i}\,\dfrac{\text{d}\,y^{i}}{\text{d}\,s}\bigg)=\text{d}\,v_{k}\,\dfrac{\text{d}\,y^{k}}{\text{d}\,s}+v_{i}\,\dfrac{\text{d}^{2}\,y^{i}}{\text{d}\,s^{2}}\,\text{d}\,s$$
Taking : $$\text{d}\,v_{k}=\partial_{j}\,v_{k}\,\dfrac{\text{d}\,y^{j}}{\text{d}\,s}\,\text{d}\,s$$
and from general equation of geodesics : $$\text{d}^{2}\,y^{i}/\text{d}\,s^{2}$$
We get :
$$\text{d}\,\bigg(v_{i}\,\dfrac{\text{d}\,y^{i}}{\text{d}\,s}\bigg)=(\partial_{j}\,v_{k}-v_{i}\,\Gamma_{kj}^{i})\,\dfrac{\text{d}\,y^{k}}{\text{d}\,s}\,\dfrac{\text{d}\,y^{j}}{\text{d}\,s}\,d\,s$$
then,
$$\text{d}\,(\vec{V}\,\cdot\,\vec{n})=(\partial_{j}\,v_{k}-v_{i}\,\Gamma_{kj}^{i}\,\text{d}\,y^{j})\,\dfrac{\text{d}\,y^{k}}{\text{d}\,s}=\text{D}\,v_{k}\,\dfrac{\text{d}\,y^{k}}{\text{d}\,s}$$
with defined Absolute differential : $$\text{D}\,v_{k}=(\partial_{j}\,v_{k}-v_{i}\,\Gamma_{kj}^{i})\,d\,y^{j}$$
Finally, I obtain the definition of Covariant derivative : $$\bigg(\nabla_{j}\,\vec{v}\bigg)_{k}=\partial_{j}\,v_{k}-v_{i}\,\Gamma_{kj}^{i}$$
How can I circumvent the issue from the factor ##r## which appears with the curvilinear coordinate ##\theta## (I speak about polar coordinates) ?
I know this is due to the curvilinear coordinates which is not orthonormal but I can't get to rid off this factor ##r## between coordinates ##(r,\theta)##.
Any help is welcome for clarifications.
I am sorry, but your notation makes your post almost impossible to read as you seem to be mixing different meanings of ##d## and ##{\rm d}## wildly. Also, I am not sure most of your post is relevant for what you are actually asking:
You have not once in your post defined what you mean with "the factor ##r##". In fact, this is the first time you mention ##r## at all apart from the beginning where you called it ##\rho##. It is unclear where you want to get rid of it because you have not written down a single equation containing it.
My main issue is about the differential of inner product :
In polar coordinates, I must take for coordinate ##y^{\theta}=\theta## but ##\dfrac{\text{d}y^{i}}{\text{d}s}## is not equal to the ##\theta## coordinate of normalized tangent vector ##\vec{n}## :
I can't write ##\vec{n}=\dfrac{\text{d}y^{i}}{\text{d}s} \vec{e_i}## with ##i=\theta## and ##\dfrac{\text{d}y^{i}}{\text{d}s}=\dfrac{\text{d}\theta}{\text{d}s}##, since in this case, norm of ##\vec{n}## could not be equal to 1.
Indeed, one must have : $$\text{d}s=\sqrt{\text{d}r^2+(r \text{d}\theta)^2}\,\,\,\,\,\,\Leftrightarrow\,\,\,\,\,\,\vec{n}\cdot\vec{n}=\sum_{i}\bigg(\dfrac{\text{d}y^{i}}{\text{d}s}\bigg)^2=1$$
And if take ##y^{1}=r## and ##y^{2}=\theta##, I have not the relation above for ##\vec{n}\cdot\vec{n}=||\vec{n}||^2=1## since this problematic factor ##r##.
I hope my question is clearer
@Orodruin
Sorry for the errors, in my notation, I consider the polar coordinates as ##(r,\theta)## . Do you understand better my issue with my last post ?
You cannot write it like that if you are using a normalised set of basis vectors ##\vec e_i##. This is generally not what we are doing in differential geometry. The coordinate basis is generally not orthonormal, as evidenced by the metric not being represented by the identity matrix.
This is not correct. Where did the metric go in your inner product?
ok, I understood my issue that was not really a issue ; into my inner product :
I can also write :
$$\text{d}(\vec{V}\cdot\vec{n} )=\text{d}(v^{j}g_{ij}\dfrac{\text{d}y^{i}}{\text{d}s})$$
and so, ##j-th## director cosine ##\alpha_j## is represented by : ##\alpha_j=g_{ij}\dfrac{\text{d}y^{i}}{\text{d}s}##
since for example in polar coordinates : ##\text{d}s^2 = g_{rr} \text{d}r^2+g_{\theta\theta}\text{d}\theta = \text{d}r^2+r^2\text{d}\theta## so :
$$1=\alpha_{r}^{2}+\alpha_{\theta}^2=\dfrac{\text{d}r^2}{\text{d}s^2}+\dfrac{r^2\text{d}\theta^2}{\text{d}s^2}$$ with ##\alpha_{\theta}## director cosine = ##\dfrac{r\text{d}\theta}{\text{d}s}##
Finaly, I get from :
the inner product between vector ##\vec{V}## and the vector of directors cosine whose ##j-th## component is equal to ##g_{ij}\dfrac{\text{d}y^{i}}{\text{d}s}##.
Thanks for your help
Sorry, I wanted to say that director cosine ##\alpha_{i}## is equal to (without Einstein notation) :
$$\alpha_{i}=\sqrt{g_{ii}}\dfrac{\text{d}y^{i}}{\text{d}s}$$
By the way, if I consider any system of coordinates ##(y^{1},y^{2})##, could we have the relation, for example director cosine ##\alpha_{1}## (here with Einstein notation) :
$$\alpha_{1}^{2}=g_{1i}\dfrac{\text{d}y^{1}}{\text{d}s}\dfrac{\text{d}y^{i}}{\text{d}s}$$
Thanks
Thanks
This would imply that ##g_{ij} \neq 0## for ##i \neq j## and so that curvilinear basis is not orthogonal , is it possible for curvilinear coordinates ?
Related to Demo of cosine direction with curvilinear coordinates
1. What is the concept behind cosine direction with curvilinear coordinates?
The concept behind cosine direction with curvilinear coordinates is to determine the direction of a vector in a curvilinear coordinate system by using the cosine of the angle between the vector and each of the coordinate axes.
2. How is cosine direction calculated in a curvilinear coordinate system?
In a curvilinear coordinate system, cosine direction is calculated by taking the dot product of the vector with each of the unit vectors along the coordinate axes. This results in a set of cosine values, which can be used to determine the direction of the vector.
3. What are some examples of curvilinear coordinate systems?
Some examples of curvilinear coordinate systems include spherical coordinates, cylindrical coordinates, and ellipsoidal coordinates. These systems are used to describe points in space that do not lie on a straight line.
4. How does cosine direction with curvilinear coordinates differ from Cartesian coordinates?
The main difference between cosine direction with curvilinear coordinates and Cartesian coordinates is that in curvilinear coordinates, the coordinate axes are not orthogonal (perpendicular) to each other. This means that the cosine direction formula must be adjusted to account for the non-orthogonal nature of the coordinate system.
5. Why is cosine direction with curvilinear coordinates useful?
Cosine direction with curvilinear coordinates is useful because it allows us to determine the direction of a vector in a non-Cartesian coordinate system, which is often necessary in scientific and engineering applications. It also helps us to understand the relationships between different coordinate systems and how they affect the direction of vectors.
  • Differential Geometry
