Density and centre of mass problem
In summary, density is a measure of how much matter is packed into a certain volume and is calculated by dividing the mass of an object by its volume. The formula for density is Density = Mass / Volume and in order to calculate it, the mass and volume of the object must be known. The centre of mass is the point where the entire mass of an object is concentrated and is related to density as it is the point around which the object will balance. These concepts are important in science as they help us understand the physical properties of objects and their stability and balance, which is crucial in various fields such as engineering, physics, and biology.
Muffintoast
A machine part consists of a thin, uniform 4.00 kg (A) bar that is 1.50 m (X) long, hinged
perpendicular to a similar bar, placed vertically downward, of mass 3.00 kg (B) and length 1.80 m (Y).
The longer bar has a small but dense 2.00 kg (C) ball at one end (the ball can be considered as a
point mass). By what distance will the center of mass of this part move horizontally and vertically if
the vertical bar is pivoted 90° counterclockwise to make the entire part horizontal (8.51)?
Centre of mass equation:
x(centre of mass) = Σm1+x1/Σm
y(centre of mass) = Σm2+y2/Σm
So I tried finding the centre of mass before machine rotated, so the [mass of A x the (x) coordinate of A] + [mass of A x the (x) coordinate of B]/all masses together so [(4 x 1.4) + (4 x 0)]/(2 + 3 + 4) = 2/3
Then, [mass of B x the (y) coordinate of A] + [mass of B x the (y) coordinate of B]/all masses together so again, [(3 x 1/8) + (3 x 0)]/ ( 2 + 3 + 4) = 5.4/9
Then, I tried finding the centre of mass after the machine rotates so that the (y) coordinate of B becomes 0. We then know that y is 0, then to find x, it is [mass of A x (x) coordinate of A] + [mass of A x (x) coordinate of B]/ all the masses added together = [(4 x 1.5) + 94 x 1.800]/(2 + 3 + 0) = 1.4666
So to find the displacement, it is the centre of mass before the rotation - the centre of mass after the rotation = 2/3 - 1.46666 = 4/5 then, 5.4/9 - 0 = 5.4/9
So the answer is x(4/5), y(5.4/9)
This answer is completely wrong, I have the correct answer which is supposed to be Δx = 0.700m, Δy = 0.700m. Please tell me where I went wrong, this is my first week of uni and I'm just so confused. :(
Hi Muffintoast! Welcome to PF! :wink:
(so A is fixed, and B moves from vertical to horizontal)
I'm very confused …
I think you've use the full length instead of the half-length for the rods, and miseed out the ball.
Start again. :smile:
Okay, I'm going to start again but one question, why do you use half length instead of the full length? The formula that my lecturer gave us said to use the length of x (A) and y (B).
What formula?
Hi Muffintoast! :smile:
(just got up :zzz:)
Muffintoast said:
… why do you use half length instead of the full length?(B).
For each large part of the total body, you must use the centre of mass of that part (times its mass) …
the centre of mass is in the middle, so you use half its length (instead of the whole distance as in eg a "point" part like the ball). :wink:
Ohh I see! To steamking, the formula that I posted on the original post. I asked my lecturer and she said that with this formula I use the half-length. I was not listening properly and I thought she said you use the full length. I'm doing all of this for the first time but I got the answer! Thanks everyone for the help!
So for the x coordinate I did, (4 x 0.75) + (3 x 1.5) + (2 x 1.5)/(4 + 3 + 2) = 10.5/9
For the y coordinate, (4 x 0) + (3 x -0.9) + (2 x -1.8)/(4 + 3 + 2) = -6.3/9
Then after the rotation, x = (4 x 0.75) + (3 x 2.40) + (2 x 3.30)/9 = 16.8/9
y = 0
The difference between the two is then Δx = 16.8 - 10.5/9 = 0.700m, Δy = 0 - - 6.3/9 = 0.700m! :D
Hey! Sorry for reviving this old thread, but I am doing this same question and am confused on the x-coordinate part.
For before the rotation, you did
x-cord: (4 x 0.75) + (3 x 1.5) + (2 x 1.5)/(4 + 3 + 2) = 10.5/9
However, shouldn't it be
x-cord: (4 x 0.75) + (3 x 0) + (2 x 0)/(4 + 3 + 2) = 3/9
instead since the 3 kg bar and the 2kg ball lie on (0,0) assuming the hinge is the origin?
UPDATE:
Oh I found out that his origin would probably be on the left hand on the bar, so there is nothing wrong with the answer. Thanks!
DaveTan:
PF doesn't like it when users necropost to old threads. The original posters to the thread may be long gone by the time you make your post, and you may be waiting for an answer in vain. :frown:
It's better to start a new thread if you have a question, and you can quote or refer to the older thread if you need to. :wink:
SteamKing said:
DaveTan:
Oh no, I'm sorry! Won't do it again!
FAQ: Density and centre of mass problem
What is density?
Density is a measure of how much matter is packed into a certain volume. It is calculated by dividing the mass of an object by its volume.
How do you calculate the density of an object?
The formula for density is: Density = Mass / Volume. In order to calculate the density of an object, you will need to know its mass and volume. Mass can be measured using a scale, while volume can be calculated by measuring the dimensions of the object and using the appropriate formula (e.g. volume of a cube = length x width x height).
What is the centre of mass?
The centre of mass is the point where the entire mass of an object is concentrated. It is the average position of all the mass in an object, and it is the point around which the object will balance.
How is the centre of mass related to density?
The centre of mass is directly related to density because it is the point where the mass of an object is concentrated. The density of an object can affect the position of its centre of mass, as objects with higher densities will have a centre of mass closer to its core.
Why is the concept of density and centre of mass important in science?
Density and centre of mass are important concepts in science because they help us understand the physical properties of objects. By understanding the density of an object, we can predict how it will interact with other objects, such as whether it will sink or float in a liquid. The centre of mass is also important in understanding the stability and balance of objects, which is crucial in various fields such as engineering, physics, and biology.
