Density of states in Fermi's golden rule
In summary, the discussion explores Fermi's golden rule and the term ##\rho(E_{final})##, which represents the density of final states. The speaker raises a concern about the potential for an infinite number of states in a given interval, using the example of a three-particle wavefunction. However, it is noted that this can be addressed through box quantization, where the states become discrete. This ensures that the final rate remains finite.
Coffee_
259
Fermi's golden rule contains a term that is the density of the final states ##\rho(E_{final})##. For my problem we have no time depending potentials so that's the same as ##\rho(E_{initial})##.
If I understand the definition of ##\rho## correctly, it's the number of states in an interval ##[E_{f},E{f}+dE]## divided by ##dE## which just gives ##dN/dE##.
However... what if there are infinite different states in this interval?
Example:
A -> B + C + D
The final wavefunction will be a three particle wavefunction that will be able to distribute any final energy ##E_f## in an infinite number of ways among the different particles ##B,C,D##. This would mean that ##\rho## is infinite here.
What am I missing?
You are missing nothing. You could do a box quantization, i.e. assume that the particles are trapped in a large box, so that the states become discrete. In the limit that the box becomes infinitely large, you recover the continuum. Note that the probability amplitude of a single state will also scale like 1/sqrt V where V is the box volume. Hence the coupling to the states will also decrease so that the final rate will remain finite.
Related to Density of states in Fermi's golden rule
1. What is the density of states in Fermi's golden rule?
The density of states in Fermi's golden rule is a mathematical concept used to describe the distribution of energy levels in a system. It is represented by the symbol "D(E)" and is a function of energy. It gives the number of available energy states per unit energy interval at a given energy level.
2. How is the density of states related to Fermi's golden rule?
Fermi's golden rule is a fundamental principle in quantum mechanics that describes the transition rate between two quantum states. The density of states is used in this rule to calculate the probability of a transition occurring between two energy levels.
3. Why is the density of states important in studying quantum systems?
The density of states is important in studying quantum systems because it allows us to understand the distribution of energy levels and how they contribute to the overall behavior of the system. It also helps in predicting the likelihood of transitions between energy levels and the overall dynamics of the system.
4. How is the density of states calculated in Fermi's golden rule?
The density of states is calculated by taking the derivative of the number of energy levels with respect to energy. It can also be calculated by integrating over all possible energy states. In Fermi's golden rule, it is used in conjunction with the transition probability to calculate the transition rate between energy levels.
5. What factors affect the density of states in Fermi's golden rule?
The density of states is affected by various factors such as the energy range of the system, the dimensions of the system, and the nature of the energy spectrum. It is also influenced by external factors such as temperature and external fields. In general, the density of states increases with increasing energy and decreases with decreasing energy.
  • Quantum Physics
