Density problem is the answer in the back wrong?
  • Thread starter Axmann
  • Tags
    Density
In summary, the density problem is a term used in science when the calculated density of a substance does not match the expected or theoretical density. Density is calculated by dividing the mass of an object by its volume using the formula Density = Mass/Volume, typically expressed as g/cm3 or g/mL. Factors such as inaccurate measurements, human error, or using the wrong formula can cause a density problem, and it can be solved by reviewing and double-checking steps and measurements. If the answer in the back of the book is wrong, it is important to retrace steps and consult with others for assistance.
Axmann
Stupid question. Problem solved. Thanks :D
Must be a decimal typo. That much density!? You are given the sample of glycerin and you are asked the density of titanium!? :confused:
FAQ: Density problem is the answer in the back wrong?
What is the density problem?
The density problem is a commonly used term in science, which refers to a situation where the calculated density of a substance does not match the expected or theoretical density.
How do you calculate density?
Density is calculated by dividing the mass of an object by its volume. The formula for density is: Density = Mass/Volume. The unit for density is usually expressed as grams per cubic centimeter (g/cm3) or grams per milliliter (g/mL).
What could cause a density problem?
A density problem can be caused by a variety of factors, such as inaccurate measurements of mass or volume, human error in calculations, or using the wrong formula. It could also be due to the presence of impurities or air bubbles in the substance being measured.
How can a density problem be solved?
To solve a density problem, it is important to review the steps and calculations used to determine the density. Double-checking measurements and using the correct formula can help identify and correct any errors. If impurities or air bubbles are present, they should be removed before taking measurements.
What should I do if the answer in the back of the book is wrong?
If the answer in the back of the book is wrong, it is important to retrace your steps and make sure all calculations and measurements were done correctly. If you are still unable to find the error, consult with your teacher or a fellow scientist for assistance.
