Dependence of Phase Velocity on Wavelength
In summary, the dielectric constant of a polymer is proportional to the inverse square root of frequency. The phase velocity of EM-waves in this polymer varies with wavelength as ##v_p = (\mu_0 \epsilon_0 \epsilon_r)^{-1/2}##. The ratio between phase and group velocities is ##\frac{v_p}{v_g} = 2##. The relation between wavenumber and wavelength is ##\lambda = \frac{2\pi}{k}## and when substituted into the expression for phase velocity, it shows a linear dependence on wavelength. The ratio between phase and group velocities should be ##\frac{v_p}{v_g} = \frac{4}{3}##
keV.92
This is Problem 7.6 from Electronic Properties of Engineering Materials by Livingston.
"Over a wide range of frequencies, the dielectric constant of a polymer is found to be proportional to the inverse square root of frequency. (a) How does the phase velocity of EM-waves vary with wavelength in this polymer? (b) What is the ratio between phase and group velocities in this material?"
This is frustrating for many reasons, not the least of which is that the answers we've been given are in terms of wavenumber, not wavelength. The (presumed) answer follows.
Problem 7-6: (a) ##v_p = Ck^\frac{1}{3} ##, (b) ##v_g = \frac{4}{3}Ck^\frac{1}{3}## so ##\frac{v_p}{v_g} = 2##
##\epsilon_r \propto \frac{1}{\sqrt{\omega}}##
Phase Velocity: ##v_p = \frac{\omega}{k}##
Group Velocity: ##v_g = \frac{\partial \omega}{\partial k}##
For an EM-Wave in a non-magnetic dielectric polymer, ##\mu = \mu_0## and ##\epsilon = \epsilon_r \epsilon_0##. From the solutions to Maxwell's Equations, we produce ##\frac{\omega}{k} = (\mu \epsilon)^{-1/2}##. Thus,
##v_p = \omega / k = (\mu_0 \epsilon_0 \epsilon_r)^{-1/2}##
By adding a constant of proportionality to the given relation, I've been able to insert the equations into each other. This produced the following:
##\frac{\omega}{k} = \frac{Ac_0^2}{\sqrt{\omega}} k##
That seems to show a linear dependence on k, and the wavelength never enters into it. This problem has me running in mathematical circles; this was the only time I got an answer that didn't just prove ##v_p = c_{polymer}##.
Do you know the relation between wavenumber and wavelength?
Shouldn't that be ##\lambda = \frac{2\pi}{k}## ?
Yes that's correct. So if you rearrange that for ##k## and then substitute into your expression for phase velocity you'll get a relationship between phase velocity and wavelength. Is that sufficient for the question you're attempting?
Also check again your ratio between phase velocity and group velocity.
Related to Dependence of Phase Velocity on Wavelength
1. What is the Dependence of Phase Velocity on Wavelength?
The dependence of phase velocity on wavelength is a fundamental concept in the study of wave behavior. It refers to the relationship between the speed at which a wave's phase travels and the wavelength of the wave. In simple terms, it describes how the size of a wave affects its speed.
2. How does the Dependence of Phase Velocity on Wavelength differ from the Dependence of Wave Velocity on Wavelength?
The dependence of phase velocity on wavelength is often confused with the dependence of wave velocity on wavelength. While both concepts involve the relationship between speed and wavelength, the former refers specifically to the speed at which the phase of a wave travels, while the latter refers to the overall speed of the wave.
3. What factors influence the Dependence of Phase Velocity on Wavelength?
There are several factors that can influence the dependence of phase velocity on wavelength, including the properties of the medium through which the wave is traveling, the type of wave (such as electromagnetic or mechanical), and the frequency of the wave.
4. Why is the Dependence of Phase Velocity on Wavelength important in understanding wave behavior?
The dependence of phase velocity on wavelength is important because it helps us understand how waves behave and interact with their surroundings. It can also provide valuable information about the properties of the medium through which the wave is traveling.
5. How is the Dependence of Phase Velocity on Wavelength used in practical applications?
The dependence of phase velocity on wavelength has many practical applications, such as in the design of communication systems, the study of seismic waves, and the development of medical imaging techniques. It is also used in various engineering and scientific fields to analyze and manipulate wave behavior.
  • Atomic and Condensed Matter
  • Quantum Interpretations and Foundations
