B Derivation for Aphelion and Perihelion Distances
  • B
  • Thread starter Thread starter bruhh
    Derivation
The formulas for perihelion and aphelion distances in an orbit are derived from the definitions of semi-major axis (SMA) and eccentricity. The perihelion distance is given by a(1-e) and the aphelion distance by a(1+e). This relationship stems from the definition of eccentricity, where the focal points of an ellipse are located at a distance of ±ea from the center. The sum of the distances from any point on the ellipse to the two foci equals 2a. Understanding these concepts is essential for grasping the derivation of these distances.
bruhh
I know the formulas for perihelion and aphelion distances in an orbit with SMA a and eccentricity e are a(1-e) and a(1+e), respectively. However, why is this? I can't seem to find any derivations for this anywhere and also cannot figure this out myself.
Astronomy news on Phys.org
Not sure what you mean by "why" here. The focus-directrix definition of an ellipse gives you this more or less instantly, but you may have to work harder with other definitions. Or are you trying to prove it from ##F=GMm/r^2##?
Basically, you have told us where you want to go but not where you are. That makes it tricky to give directions.
See any classical mechanics textbook
It follows from the definition of the eccentricity: the focal points of an ellipse are at a distance ## \pm e a ## from the center. And for perihelion and aphelion, as for any points on the ellipse, the sum of the distances to the foci must be ## 2a ##.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
