PhiJ
- 44
I really don't know if I'm in the right subforum...
I've started reading this text on statistical mechanics from MIT, but I'm stuck on page 2. Here's the statement:
Let the equilibrium state of systems A, B, and C be described by the coordinates
{A1, A2,· · ·}, {B1, B2,· · ·}, and {C1, C2,· · ·} respectively. The assumption that A and C are in equilibrium implies a constraint between the coordinates of A and C, i.e. a change in A1 must be accompanied by some changes in {A2,···;C1, C2,···} to maintain equilibrium of A and C. Denote this constraint by
fAC(A1, A2,···;C1, C2,···) = 0. (I.1)
The equilibrium of B and C implies a similar constraint
fBC(B1, B2,···;C1, C2,···) = 0. (I.2)
Each of the above equations can be solved for
C1 to yield
C1 = FAC(A1, A2,···; C2,···) (I.3a)
C1 = FBC(B1, B2,···; C2,···) (I.3b)
C1 to yield
Thus if C is separately in equilibrium with A and B we must have
FAC(A1, A2,···; C2,···) = FBC(B1, B2,···; C2,···) (I.4)
However, according to the zeroth law there is also equilibrium between A and B, implying
the constraint
fAB(A1, A2,···;B1, B2,···) = 0. (I.5)
Therefore it must be possible to simplify eq.(I.4) by cancelling the coordinates of C.
the constraint
(I.1) through (I.5) above.
I understand up to I.2. For I.3 I'm going to assume there is a unique solution - I'm sure the solution isn't always unique, but it means their argument is correct and I don't have to play mind twister to agree. So given that assumption I'm happy with I.3. I.4 is then obviously true, and I.5 is obviously true by the zeroth law.
I suppose 'cancel the Cs' means substitute some constants into the values for CX, so define:
FA(A1, A2,···) = FAC(A1, A2,···; c2,···)
FB(B1, B2,···) = FBC(B1, B2,···; c2,···)
where cx is a constant.
But then:
FA(A1, A2,···) - FB(B1, B2,···) = 0
And we can define fAB = FA - FB
i.e. we already have a constraint in terms of A and B. Therefore the zeroth law is not a foundational assumption, it's something you can prove. I'm sure I'm wrong on that count, but I can't see why. I realized I've made an assumption to accept I.3, but is I.3 wrong? It's stated in the text.
