I Derivation of Cauchy-Schwarz Inequality
member 731016
For this,
I don't understand how they got from (1) to (2)? Dose someone please know what binary operation allows for that?
I also don't understand how they algebraically got from line (2) to (3).
Many thanks!
jedishrfu said:
They used the geometric definition of vector dot product which is:
##u \cdot v = |u| |v| cos(\theta)## where its understood that ##\theta## is the angle between u and v
https://en.wikipedia.org/wiki/Dot_product
Thank you for your reply @jedishrfu !
Sorry if I was not clear. How did they go from ## -|v||w| ≤ v \cdot w ≤ |v||w| ## be equal to ##|v \cdot w| ≤ |v||w|##? The textbook dose not show any immediate steps.
I also don't know what allowed them to multiply all of ##-1 ≤ \cos\theta ≤ 1## by ##|v||w| ## to get line (2).
Many thanks!
Try it the other way. What does ##|x|\leq a## tell you about the range of allowed values for ##x##?
If one number (e.g. ##\cos\theta##) is less than another (e.g. ##1##) and I multiply both by some positive value (e.g. ##|v||w|##), do you think the product with the smaller value (##|v||w|\cos\theta##) could ever be larger than the product with the larger value (##1|v||w|##)?
Likes member 731016
Thank you for your reply @Ibix!
The range of allowed values of x have to such that their abs is less than or equal to a.
Many thanks!
No I don't think so.
Many thanks!
Callumnc1 said:
##-|v||w| ≤ v \cdot w ≤ |v||w| ## be equal to ##|v \cdot w| ≤ |v||w|##?
By definition, if ## -b \leq a \leq b ## then we write this as ## |a| \leq b##
Likes member 731016 and jedishrfu
Thank you for your reply @malawi_glenn! Sorry, where did you read that is true? I am not sure where it is derived from. I have never seen that before sorry.
Many thanks!
Many thanks!
Any math textbook on pre calc should cover this
https://en.wikipedia.org/wiki/Absolute_value
And it is not derived it is a definition, a way of writing more compact
Likes member 731016
Draw a number line. Mark ##0## and ##\pm b##. What region of this line can ##a## lie in if ##|a|\leq b##? What region can it lie in if ##-b\leq a\leq b##?
Likes member 731016
Thank you for your reply @lbix ! I will do some thinking. Many thanks!
If ##-b \le a \le b##, then ##a \le b## and ##-b \le a## (or, ##-a \le b##). So ##\pm a \le b##. Since ##|a|## is either ##a## or ##-a##, then ##|a| \le b##.
Likes member 731016, DaveE and Ibix
Thank you for your reply @Euge!
Could you also equally just take the absolute value of the of both sides of the inequality ##\pm a \le b## instead of using the definition of absolute value? This would give ##|a| \le |b|##
Many thanks!
In general, the inequality ##a \le b## does not imply ##|a| \le |b|##. For example, ##-2 \le 1## but ##|-2| > |1|## since ##|-2| = 2## and ##|-1| = 1##.
Likes Greg Bernhardt, member 731016 and malawi_glenn
