Derivation of Euler Lagrange's equations from D'alemberts principle
In summary, the conversation discusses the derivation given in Goldstein's book and the use of generalized configuration-space coordinates and the Lagrangian version of the Hamilton principle. It also touches on the issue of properly defining and explaining concepts in textbooks.
PrathameshR
35
In the derivation given in Goldstein's book it is given
I can't understand from where it comes. It's not at all trivial for me but it's presented as if it's trivial.
The point is that you introduce a set of generalized configuration-space coordinates, ##q_j##, describing the position of your particles as
$$\vec{r}_i=\vec{r}_i(q).$$
Then you have
$$\vec{v}_i=\frac{\mathrm{d} \vec{r}_i}{\mathrm{d} t} = \sum_j \frac{\partial \vec{r}}{\partial q_j} \dot{q}_j.$$
Now you have to know that in the Lagrangian version of the Hamilton principle you consider the space ##(q_j,\dot{q}_j)## with the ##q_j## and ##\dot{q}_j## as independent (!) variables, i.e., whenever you write down a partial derivative with respect to ##q_j## or the ##\dot{q}_j## you consider these variables as the independent variables, and the partial derivative means in taking that derivative you consider all variables fixed except the one with respect to which you differentiate. Then from the above formula, it's immediately clear that
$$\frac{\partial \vec{v}_i}{\partial \dot{q}_j}=\frac{\partial \vec{r}_i}{\partial q_j}.$$
Then you have
Sorry but there are a lot of dollar signs and hashtags in your post . I'm not able to read it properly.
Then, something's wrong with your browser. You should see formulae instead of the LaTeX source code.
I was using physics forum app on my android phone. When I opened your reply in chrome browser it showed proper notations and not the source code. Thanks for your answer. The independence of q and q dots is the key here (?). It'll take some time to sink in. Thanks again.
Yes, the only problem is that I don't know of any textbook that mentions this definition, and when I've first seen the Hamiltonian principle, I stumbled over the very same problem. I don't know, why no textbook writer thinks that you just should tell your readers your definitions properly! :-((. Don't worry, you'll get used to that soon.
[emoji4] i hope so
Likes vanhees71
FAQ: Derivation of Euler Lagrange's equations from D'alemberts principle
What is the D'alembert's principle?
D'alembert's principle is a fundamental principle in classical mechanics that states that the sum of the external forces acting on a system and the product of the mass of the system and its acceleration is equal to zero. In other words, it states that the net force on a system is equal to the product of its mass and acceleration.
What is the Euler Lagrange's equation?
The Euler Lagrange's equation is a mathematical equation that is used to describe the motion of a physical system. It is derived from the principle of least action, which states that the path taken by a system between two points is the one that minimizes the action, a measure of the system's energy. The Euler Lagrange's equation is important in the field of mechanics, as it allows for the calculation of the trajectory of a system based on its initial and final states.
How do you derive Euler Lagrange's equations from D'alembert's principle?
To derive Euler Lagrange's equations from D'alembert's principle, one must first express the external forces acting on the system in terms of generalized coordinates and their derivatives. Then, using the principle of virtual work, the external forces can be eliminated from the equation. Finally, by applying the principle of D'alembert, the remaining equation can be simplified to obtain the Euler Lagrange's equation.
What is the significance of Euler Lagrange's equations in physics?
Euler Lagrange's equations are significant in physics as they provide a powerful tool for analyzing the motion of physical systems. They allow for the calculation of the trajectory of a system based on its initial and final states, without the need for solving complex differential equations. Additionally, they are used in various fields of physics, including mechanics, quantum mechanics, and relativity.
Are there any limitations to the use of Euler Lagrange's equations?
While Euler Lagrange's equations are a useful tool in physics, they do have some limitations. They are only applicable to systems that can be described by a Lagrangian function, which may not be possible for all physical systems. Additionally, they do not take into account non-conservative forces, such as friction, which may significantly affect the motion of a system.
