I Derivation of Fluid Pressure In A Gravitational Field
The derivation of fluid pressure under gravity presented in the discussion contains a critical flaw regarding the assumption of uniform pressure over the volume. The equation used, P = 2ρgh, incorrectly implies that pressure is constant, which contradicts the principles of fluid mechanics. The value of h is misapplied, as it represents both the height for work done and a factor in volume calculations. This misunderstanding leads to an incorrect conclusion about fluid pressure. Accurate derivation must consider the variation of pressure with depth in a fluid.
bmarc92
Given that ##P = ρgh##, there's obviously a problem with the following derivation of fluid pressure under gravity. Can someone spot the flaw?
$$W = mgh$$
$$W = ρVgh$$
$$F \cdot dh = ρVgh$$
$$F \cdot dh = ρ(Ah)gh$$
$$F \cdot dh = ρgAh^{2}$$
$$\frac{d(F \cdot dh)}{dh} = \frac{d(ρgAh^{2})}{dh}$$
$$F = 2ρgAh$$
$$\frac{dF}{dA} = \frac{2ρgAh}{dA}$$
$$P = 2ρgh$$
Your derivation assumes that the pressure is uniform over the volume V. This is not correct.
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Hello, I'm joining this forum to ask two questions which have nagged me for some time. I am in no way trolling. They both are presumed obvious, yet don't make sense to me. Nobody will explain their positions, which is...uh...aka science. I also have a thread for the other question. Yes, I'm questioning the most elementary physics question we're given in this world. The classic elevator in motion question: A person is standing on a scale in an elevator that is in constant motion...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
