Derivation of free fields... coefficient question
In summary, Dan found a problem with Weinberg's derivation of the Feynman rules for QED, specifically the fact that the ##2 \pi##s in the equation for the anti-commutators get lost. Weinberg insists on keeping the ##2 \pi##s in order to get rid of the extra factor in the Fourier integral, but eventually other sources of information (like other books) get rid of the extra ##2 \pi##s.
topsquark
Insights Author
MHB
2,020
827
Editing... Please be patient!
I came across this difficulty comparing several versions of the Feynman rules for QED. I traced the problem back to a statement of Weinberg's in "The Quantum Theory of Fields (Vol 1)", Chapter 5, page 195. Weinberg is busy setting up for deriving free field expressions for different particle types. He has got to the point where he is deriving the field operators as an integral expression. Specifically, he derives two equations:
##\displaystyle \psi_l^+(x) = \sum_{\sigma , n} (2 \pi )^{3/2} \int d^3p u_l(\textbf{p}, \sigma, n) e^{i p \cdot x} a(\textbf{p}, \sigma, n)##
and
##\displaystyle \psi_l^-(x) = \sum_{\sigma , n} (2 \pi )^{3/2} \int d^3p v_l(\textbf{p}, \sigma, n) e^{-i p \cdot x} a^{\dagger} (\textbf{p}, \sigma, n)##
Now, I understand the overall features here. But Weinberg continues on to say
The factors ##(2 \pi )^{3/2}## could be absorbed into the definition of ##u_l## and ##v_l##, but it is conventional to show them explicitly in these Fourier integrals.
Now, it's a Fourier integral, so I do see the value in showing the ##2 \pi##s. But by the time the Feynman rules are derived, practically everyone has redefined the field operators so that the ##(2 \pi )^{3/2}## factor disappears.
And when we get to the amplitude, Weinberg's insistence on keeping the ##2 \pi##s alters the amplitude compared to other sources. As an example, see here, equations 2.1 and 2.2. Weinberg's set of Feynman rules gives an overall factor of ##(2 \pi)^{-6}## to these amplitudes.
How do we get rid of those extra ##2 \pi##s?
Thanks!
-Dan
Addendum: Problem solved! Weinberg's extra ##(2 \pi)^{-3/2}## factor in his version of the Feynman rules is there to get rid of that extra ##(2 \pi)^{3/2}## factor in the Fourier integral. I saw it just as I posted this.
Likes hutchphd
Congratulations on a very compact post.
  • Haha
Likes topsquark
This is a mess in the literature, and it drives you always nuts, if you like to compare results from different sources. Weinberg uses the non-relativistic convention for the anti-commutators (see p. 325 in Weinberg's book),
$$[\hat{a}(\vec{p},\sigma),\hat{a}^{\dagger}(\vec{p}',\sigma')]_+=[\hat{b}(\vec{p},\sigma),\hat{b}^{\dagger}(\vec{p}',\sigma')]_+=\delta^{(3)}(\vec{p}'-\vec{p}) \delta_{\sigma \sigma'}$$
and all other combinations of anti-commutators among annihilation and creation operators vanishing. That as the advantage that the corresponding momentum eigen states,
$$|a,\vec{p},\sigma \rangle=\hat{a}^{\dagger}(\vec{p},\sigma) |\Omega \rangle$$
and analogously for anti-particles are normalized to a ##\delta##-distribution.
What's never changing is the equal-time (anti-)commutators between the field operators and the conjugate field momenta, which are always (using the canonical formalism as a shortcut in comparison to the more tedious but much more insightful from a fundamental point of view, where everything is built up from Lorentz invariance and microcausality, as explained in the chapters before) read
$$[\hat{\phi}_j(t,\vec{x}),\hat{\Pi}_k(t,\vec{y})]_{\pm} = \mathrm{i} \delta^{(3)}(\vec{x}-\vec{y}) \delta_{jk}$$
for some fields ##\phi_j## and their canonical conjugated field momenta ##\hat{\Pi}_k## (for fermions/half-integer spin the upper and bosons/integer spin the lower sign).
Likes topsquark
I know. I like his style of presentation, but occasionally it's useful to reference other sources and his conventions can get in the way. I've been writing some stuff on the Feynman rules for QED and his electron propagator is:
## \dfrac{\left ( \dfrac{-i}{(2 \pi )^4 } \right ) \dfrac{ -i \not \! q + m}{q^2 + m^2 - i \epsilon} ##
I haven't found that anywhere else. Most everyone else seems to use
##\dfrac{i (\not \! q + m)}{q^2 - m^2 - i\epslion}##
This part I already knew: His convention for the ##\gamma## matrices is i times the "typical" choice, and he's using different metric. (Frankly, I use his metric, but anyway...)
I presume that there's a reason why he would choose this, and I can certainly work with it now that I know where the factors come from, but it can be really annoying to check my calculations with something I find online!
-Dan
Addendum: What did I do wrong with the LaTeX? That should be right!
## \left ( \dfrac{-i}{(2 \pi )^4 } \right ) \dfrac{ -i \not \! q + m}{q^2 + m^2 - i \epsilon} ##
##\dfrac{i (\not \! q + m)}{q^2 - m^2 - i\epsilon}##
-Dan
That's the LaTeX-corrected posting :-). What puzzles me most is the i in front of the q-slash.
Likes topsquark
Weinberg defines the ##\gamma##s as
##\gamma^0 = -i \begin{pmatrix} 0 & I \\ I & 0 \end{pmatrix}##
##\gamma^i = -i \begin{pmatrix} 0 & \sigma^i \\ -\sigma^i & 0 \end{pmatrix}##
which makes his
##-i \not \! q + m = -i \gamma^0 q_0 - i \gamma^i q_i + mI = \begin{pmatrix} 0 & -imI -i q_0I - i \sigma^i q_i \\-m - i Iq_0 + i \sigma^i q_i & 0\end{pmatrix}##
##\hphantom{XXXXX} = - \begin{pmatrix} 0 & imI + iq_0I + \sigma^i q_i \\ imI + i Iq_0 - i \sigma^i q_i & 0 \end{pmatrix}##
vs the "usual" standard
##i ( \not \! q + m ) = \begin{pmatrix} im & i Iq_0 + i \sigma^i q_i \\ i Iq_0 - i \sigma^i q_i & -im \end{pmatrix}##
I'm still looking into this to see how this makes the amplitude come out right, but I'm thinking we essentially get an overall factor of i out of it. As we are going to square the modulus in the end, this won't matter.
-Dan
Likes vanhees71
FAQ: Derivation of free fields... coefficient question
What is meant by "free fields" in quantum field theory?
Free fields in quantum field theory refer to fields that are not interacting with other fields. They are solutions to the equations of motion derived from a Lagrangian that does not include interaction terms. In this context, free fields can be quantized independently, and their behavior can be analyzed without the complexities introduced by interactions.
How is the coefficient in the free field Lagrangian derived?
The coefficients in the free field Lagrangian are derived from the requirements of dimensional analysis and the physical properties of the field. For scalar fields, the Lagrangian typically includes a kinetic term and a mass term, with coefficients that ensure the correct dimensions and units. For example, the kinetic term for a scalar field is generally of the form \(\frac{1}{2} \partial_\mu \phi \partial^\mu \phi\), where the coefficient ensures the term has the correct dimensions of action.
What role do coefficients play in the quantization of free fields?
Coefficients in the Lagrangian of free fields are crucial for determining the mass and interaction strength of the particles described by the field. During quantization, these coefficients influence the propagators and the resulting Feynman rules, which dictate how particles interact and propagate through spacetime. Properly chosen coefficients ensure that the theory remains consistent and predictive.
Can the coefficients in the free field Lagrangian change under transformations?
Yes, the coefficients in the free field Lagrangian can change under certain transformations, such as Lorentz transformations or gauge transformations. However, physical observables must remain invariant under these transformations. This invariance leads to constraints on the form of the coefficients and ensures that the underlying physics is preserved across different frames of reference.
How do the coefficients affect the particle spectrum in free field theories?
The coefficients in the free field Lagrangian directly impact the mass of the particles in the theory. For instance, the mass term in the Lagrangian contributes to the dispersion relation of the particles, determining their energy-momentum relationship. Changes in the coefficients can lead to different particle masses and, consequently, alter the spectrum of particles that can be observed in the theory.
