Derivation of Phase Angle Addition Formula
Otherwise, you can use the law of cosines to derive the angle formula. In summary, for two phasors a and b with magnitudes A and B respectively and phase angles \phi_{a} and \phi_{b}, the sum of the phasors (p) has a magnitude of P^{2} = A^{2} + B^{2} and a phase angle of \phi_{p} = -tan^{-1}(\frac{B}{A}), which can be derived using the law of cosines when the phasors are not orthogonal.
kataya
23
For two phasors [tex]a[/tex] and [tex]b[/tex], with magnitudes of A,B respectively and phase angles of [tex]\phi_{a)[/tex] and [tex]\phi_{b}[/tex], the angle of the sum of the phasors (call it p) has a magnitude of:
[tex]P^{2} = A^{2} + B^{2}[/tex] ,
and a phase angle of:
[tex]\phi_{p} = -tan^{-1}(\frac{B}{A})[/tex]
The magnitude identity makes sense, as it is the geometric sum of the two vectors, but I am having trouble deriving the phase angle identity.
My original idea was to have something like this:
[tex]\phi_{p} = tan^{-1}(\frac{A^{2}sin^{2}\phi_{a} + B^{2}sin^{2}\phi_{b}}{A^{2}cos^{2}\phi_{a} + B^{2}cos^{2}\phi_{b}})[/tex]
But I could not get anywhere with that, or at the very least work it into the form given above.
Does anyone know how to derive the angle formula? Many thanks
The formulas for magnitude and phase you gave are true only if the two phasors are orthogonal.
The phase angle addition formula can be derived using the properties of trigonometric functions and the definition of phasors. First, let's define the two phasors a and b as:
a = A(cos(\phi_a) + isin(\phi_a))
b = B(cos(\phi_b) + isin(\phi_b))
where A and B are the magnitudes of the phasors and \phi_a and \phi_b are their respective phase angles.
Now, let's consider the sum of these two phasors, denoted as p:
p = a + b = A(cos(\phi_a) + isin(\phi_a)) + B(cos(\phi_b) + isin(\phi_b))
Using the properties of complex numbers, we can expand this equation to get:
p = (Acos(\phi_a) + Bcos(\phi_b)) + i(Asin(\phi_a) + Bsin(\phi_b))
The magnitude of p can be calculated using the Pythagorean theorem:
|p| = \sqrt{(Acos(\phi_a) + Bcos(\phi_b))^2 + (Asin(\phi_a) + Bsin(\phi_b))^2}
Simplifying this equation, we get:
|p| = \sqrt{A^2cos^2(\phi_a) + B^2cos^2(\phi_b) + 2ABcos(\phi_a)cos(\phi_b) + A^2sin^2(\phi_a) + B^2sin^2(\phi_b) + 2ABsin(\phi_a)sin(\phi_b)}
Using the trigonometric identity cos^2(x) + sin^2(x) = 1, we can further simplify this equation to get:
|p| = \sqrt{A^2 + B^2 + 2AB(cos(\phi_a)cos(\phi_b) + sin(\phi_a)sin(\phi_b))}
Using the trigonometric identity cos(x-y) = cos(x)cos(y) + sin(x)sin(y), we can write the above equation as:
|p| = \sqrt{A^2 + B^2 + 2ABcos(\phi_a - \phi_b)}
Now, we can use the inverse tangent function to find the phase angle of p:
\phi_p = tan^{-1}(\frac{Im(p)}{Re(p)})
FAQ: Derivation of Phase Angle Addition Formula
1. What is the "Derivation of Phase Angle Addition Formula"?
The Derivation of Phase Angle Addition Formula is a mathematical process that explains how to calculate the phase angle of a complex number by adding the phase angles of its real and imaginary components. This formula is commonly used in physics, engineering, and other scientific fields to analyze the behavior of waves and oscillations.
2. Why is the "Derivation of Phase Angle Addition Formula" important?
The Derivation of Phase Angle Addition Formula is important because it allows us to understand and predict the behavior of complex systems, such as electromagnetic waves, sound waves, and mechanical vibrations. It also helps us solve practical problems in various fields, including signal processing, communications, and circuit analysis.
3. How is the "Derivation of Phase Angle Addition Formula" derived?
The "Derivation of Phase Angle Addition Formula" is derived using trigonometric identities and the rules of complex numbers. It involves converting the complex number into polar form, where the phase angle can be easily calculated by using the tangent function. By manipulating the equations, we can arrive at the final formula for adding phase angles.
4. Can the "Derivation of Phase Angle Addition Formula" be applied to any type of complex number?
Yes, the "Derivation of Phase Angle Addition Formula" can be applied to any complex number, regardless of its form (rectangular or polar). The formula remains the same, but the method of calculation may vary depending on the given form of the complex number.
5. Are there any limitations to the "Derivation of Phase Angle Addition Formula"?
The "Derivation of Phase Angle Addition Formula" has limitations when dealing with certain types of complex numbers, such as those with a zero magnitude or a negative real part. In such cases, the formula may not yield accurate results and other methods must be used. Additionally, the formula is only applicable for adding two complex numbers, and cannot be used for more than two numbers.
