Derivation of the Area Formula for Triangles Using Axioms
In summary, all triangular regions are measurable and have an area of half the product of their base length and height. This is because they can be constructed from the intersection of two rectangles, which are known to be measurable, and the area of a rectangle can be calculated as the product of its base length and height. By inscribing the triangle within a rectangle and using congruent triangles, we can see that the area of the triangle is precisely half the area of the rectangle. Therefore, any arbitrary triangle can be measured and its area can be calculated using this formula.
vrble
From Apostol's Calculus Volume I, "Area as a Set Function"
1. Homework Statement :
Right triangular regions are measurable because they are constructed from the intersection of two rectangles. Prove that all triangular regions are measurable and have an area of the product of one-half, their base length, and their height.
(The class of all measurable sets is referred to as M and the following axioms are relevant to this problem.)
a(x) = Area of x
1. If S and T are both sets in M, then S ∪ T is in M and a(S ∪ T) = a(S) + a(T) - a(S ∩ T).
2. All rectangles are members of M, and their area can be calculated as the product of their base length and their height.
Take an arbitrary triangle and take the longest side as the base and extend a parallel line from it's height to it's base, thus forming two right triangles. This can be done to any triangle, thus by axiom 1 and the previously known information that all right triangles are measurable we can conclude that all triangular regions are also measurable. As for the area of this arbitrary triangular region, we inscribe it within a rectangle with base and height equal to that of the triangle. This forms two additional triangles that are congruent to their respective counterparts in the inscribed triangle and the sum of these parts equals the area of the entire rectangle. We find that this inscribed triangle is precisely one half the area of the rectangle. Thus the area of the triangle is equal to one-half times its base times its height.
a(x) = Area of x
Do you have a question?
If you're asking whether your proof is reasonable, it looks OK to me except for one part.
I think I understand what you're trying to say, but what you actually say is pretty confused.
"extend a parallel line" -- I think you mean "extend a perpendicular from the top vertex of the triangle to the base..."
When you say "extend a parallel line" the obvious question is "parallel to what?"
Yes, I meant "Take the longest side of the triangle as its base and extend a perpendicular from the vertex opposite the base." Sorry, I must have been thinking about something else while writing up the proof. Is there any improvements that could be made?
Related to Derivation of the Area Formula for Triangles Using Axioms
What is the area formula for triangles?
The area formula for triangles is A = 1/2 * base * height, where A is the area, base is the length of the triangle's base, and height is the perpendicular distance from the base to the opposite vertex.
What are axioms?
Axioms are statements or principles that are accepted as true without needing to be proven. They serve as the basis for mathematical reasoning and proof.
How do axioms relate to the derivation of the area formula for triangles?
In the derivation of the area formula for triangles, axioms are used as the starting point for the logical reasoning process. The formula is derived from these axioms through a series of deductive steps.
Can the area formula for triangles be proven using axioms?
Yes, the area formula for triangles can be proven using axioms. By starting with the axioms and using logical deductions, the formula can be derived and proven to be true.
Why is it important to derive the area formula for triangles using axioms?
Deriving the area formula for triangles using axioms helps to establish a solid foundation for this mathematical concept. It also allows for a deeper understanding of the formula and its relationship to other mathematical principles.
  • General Math
