Derivation of the Casimir energy in flat space
In summary, the derivation of the Casimir energy involves summing over all possible excitation modes in ##k##-space. The assumption of periodic boundary conditions allows for the integration of two of the dimensions in ##k##-space, which is possible due to the large size of the plates. This allows for the approximation of the sum by an integral, but only for the momentum components along the plates and not perpendicular to them. This is because the plates are assumed to be much larger than their distance.
highflyyer
28
I am trying to understand the derivation of the Casimir energy from https://en.wikipedia.org/wiki/Casim...f_Casimir_effect_assuming_zeta-regularization.
At one point, the derivation writes the following:
The vacuum energy is then the sum over all possible excitation modes ##\omega_{n}##. Since the area of the plates is large, we may sum by integrating over two of the dimensions in ##k##-space. The assumption of periodic boundary conditions yields
$$\langle E \rangle=\frac{\hbar}{2} \cdot 2 \int \frac{A dk_x dk_y}{(2\pi)^2} \sum_{n=1}^\infty \omega_n$$
What does the size of the plates have to do with being able to integrate over two of the dimensions in ##k##-space? I don't quite see the connection.
Thank you so much in advance for any comments.
For example they don't need to care for diffraction. And they don't care about what is happening around corners since that part is very small when you have large plate.
If you have periodic boundary conditions in a cuboid volume, the momenta are quantized: ##p_j=\frac{2 \pi}{L_j} n## with ##n \in \mathbb{Z}##. For large ##L_j## you can often approximate a sum over ##p_j## by an integral
$$\sum_{p_j} \rightarrow \frac{L}{2 \pi \hbar} \int_{\mathbb{R}} \mathrm{d}p_j.$$
Here you assume that the plates are very large compared to their distance. Thus you can use the approximation of the sum by an integral for the momentum components along the plates but not for the one perpendicular to it.
Likes highflyyer and Demystifier
Thank you.
Related to Derivation of the Casimir energy in flat space
1. What is the Casimir energy in flat space?
The Casimir energy in flat space is a type of vacuum energy that arises due to the presence of boundaries in a quantum field theory. It is named after the Dutch physicist Hendrik Casimir, who first predicted its existence in 1948.
2. How is the Casimir energy derived in flat space?
The Casimir energy in flat space is derived using the Casimir effect, which is the force that arises between two uncharged parallel plates due to the quantum fluctuations of the vacuum. This effect can be calculated using the stress-energy tensor of the quantum field and the geometry of the plates.
3. What is the significance of the Casimir energy in flat space?
The Casimir energy in flat space has important implications in quantum field theory and cosmology. It is responsible for the stability of matter and has been used to explain phenomena such as the Lamb shift and the van der Waals force.
4. Are there any experimental confirmations of the Casimir energy in flat space?
Yes, there have been several experiments that have confirmed the existence of the Casimir energy in flat space. These include the measurement of the Casimir force between parallel plates and the observation of the Casimir-Polder force between an atom and a surface.
5. Can the Casimir energy in flat space be modified or controlled?
Yes, the Casimir energy in flat space can be modified or controlled by changing the geometry of the boundaries or by using materials with different properties. This has led to the development of technologies such as Casimir force-based microelectromechanical systems (MEMS).
