Derivation of the oscillation period for a vertical mass-spring system
In summary, the derivation of T= 2π√m/k for a horizontal mass-spring system equates to the general equation of acceleration for simple harmonic motion. However, in a vertical system, the constant force of gravity needs to be considered and thus the equation for the period of steady state bouncing is different. The restoring force in this case is the resultant force, which acts towards equilibrium. The elastic force in the cord acts towards the natural length of the cord. The change in tension is proportional to the change in extension during oscillation, as the equilibrium position of the cord balances gravity and the change in tension becomes the net force.
User1265
29
I am confused how the time period of a vertical spring system is T= 2π√m/k, when there is the weight of the mass to consider?
T= = 2π *√m/k
I understand the derivation of T= 2π√m/k is a= -kx/m, in a mass spring system horizonatally on a smooth plane,
as this equated to the general equation of acceleration of simple harmonic motion , a= - 4π^2 (1/T^2) x
but surely when in a vertical system , taking downwards as -ve, ma = kx - mg , so I don't understand why in the following context of the question below
A bungee jumper of mass 70kg has a light linear elastic bungee cord with coefficient of elasticity 153N/m. He jumps from the platform and then bounces up and down at the end of the bungee cord. Assuming that the amplitude of bouncing is small enough that the bungee cord is never slack, what is the period of the steady state bouncing?
Why is T = 2π *√m/k is used to calculate the period, surely it can't have the same derivation as a horizontal spring-mass system as there is the constant force of gravity to consider?
My solution was intially to use:
Initially I used T = 2π *√m/k, but I had never really considered if I could get to the same derivation using a vertical spring system until now.
Gravity adds a constant downward force. The initial extension of the rope, i.e. to the equilibrium position, adds an equal and opposite force. We can take that as constant and just consider variations from there.
During oscillation, the change in the tension is proportional to the change in extension.
Suppose m = 1 kg and k = 100 N/m. If you need to calculate gravitational force, let the magnitude of g = 10 m/s2 for simplicity in calculations.
Place the spring+mass system horizontally on a frictionless surface. When the mass is at its equilibrium position (x = 0), F = 0. When the mass is at x = -0.01 m (to the left of the equilbrium position), F = +1 N (to the right). When the mass is at x = +0.01 m (to the right of the equilibrium position), F = -1 N (to the left).
Now place the spring+mass system vertically, with the spring's anchor point at the top. The spring stretches and settles into a new equilibrium length. Call the mass's equlibrium position x = 0, with x positive upwards and negative downwards.
What is the net force on the mass at x = 0?
What is the net force on the mass at x = -0.01 m (below the equilibrium position)?
What is the net force on the mass at x = +0.01 m (above the equilibrium position)?
Likes User1265
So what would be considered the restoring force? Is it just the tension or the resultant force which would be acting towards the equilbrium?
As the term 'restoring force' indicates: it acts towards equilibrium, so it must be the resultant force (the Fnet in F = ma ).
But doesn't the elastic force in the cord acts towards equilibrium too ?
No. It acts towards the natural length of the cord.
Likes User1265
Thank you, and the restoring force proportional to -ve displacement?
Why change in tension and not tension is proportional to displacement at an instant in the elastic cord as the cord is originally displaced from its natural length?
Tension is proportional to the extension, of course, but that does not lead to an understanding of why gravity makes no difference to the oscillation.
The relevant point is that in the equilibrium position the tension balances gravity, and extension relative to that position is proportional to the change in tension. The change in tension becomes the net force.
Likes User1265
Related to Derivation of the oscillation period for a vertical mass-spring system
1. What is a vertical mass-spring system?
A vertical mass-spring system is a physical system that consists of a mass attached to a spring that is suspended vertically from a fixed point. The mass is free to move up and down due to the force of gravity acting on it.
2. What is the significance of deriving the oscillation period for a vertical mass-spring system?
The oscillation period is important because it tells us how long it takes for the mass to complete one full cycle of motion, from its highest point to its lowest point and back. This information can be used to understand and predict the behavior of the system.
3. How is the oscillation period for a vertical mass-spring system calculated?
The oscillation period for a vertical mass-spring system can be calculated using the formula T = 2π√(m/k), where T is the period, m is the mass of the object, and k is the spring constant. This formula is derived from the principles of simple harmonic motion.
4. What factors can affect the oscillation period of a vertical mass-spring system?
The oscillation period can be affected by the mass of the object, the stiffness of the spring (determined by the spring constant), and the force of gravity. Other factors such as air resistance and friction can also play a role in the system's behavior.
5. How can the oscillation period be measured in a real-life experiment?
One way to measure the oscillation period in a real-life experiment is by using a stopwatch to time the number of oscillations the mass completes in a given amount of time. The period can then be calculated by dividing the total time by the number of oscillations. Other methods, such as using motion sensors or video analysis, can also be used to measure the oscillation period.
