Derivations of the Decay Constant Equation.
In summary, the equation T^{\frac{1}{2}} = \frac{ln(2)}{\lambda} is used to calculate the decay constant lambda. The equation is separable and first order, and can be solved for T_{1/2} using the laws of logarithms.
_Mayday_
808
I have used this equation in the past but have no knowledge of how the equation is formed. I will probably learn about it next year, but that is a long time to wait for a burning question. :shy:
Here is the equation I am talking about. I would like be sure that I know what everything stands for before I understand how it is formed.
[tex]T^{\frac{1}{2}}[/tex] is the Half-Life
[tex]ln(2)[/tex] I know this is a logarithm, but I am not sure why this is used in particular if anyone could explain why this is used I would be most grateful.
[tex]\lambda[/tex] is the Decay Constant
Here the equation is.
[tex]T^{\frac{1}{2}} = \frac{ln(2)}{\lambda}[/tex]
Any help on how this equation is constructed would be great, It would be nice to see a step by step method in how you would get there. I'm not sure if there is really much to say on the construction, but even an explantion on how it is constructed would be nice.
From experimental observation we know that the decay rate is proportional to the number of radioactive nuclei (N) in a given sample. That is,
[tex]\frac{dN}{dt} \propto N \Rightarrow \frac{dN}{dt} = -\lambda N[/tex]
The negative sign indicates that it is a decay (i.e. decrease) rather than an increasing function. [itex]\lambda[/itex] is the constant of proportionality and is called the decay constant. Now, the differential equation is first order and separable. I wouldn't imagine that you've solved any ODE's before so I'll give a fair amount of detail.
First we divide by N, assuming of course that [itex]N\neq0[/itex], which is a valid assumption since if N=0, there would be no radioactive nuclei and hence no decay,
[tex]\frac{1}{N}\frac{dN}{dt} = -\lambda[/tex]
Now we integrate with respect to t,
[tex]\int\frac{1}{N}{\frac{dN}{dt}dt = -\lambda\int dt[/tex]
Now, you can think of the next step as canceling the dt's on the RHS. This isn't rigorously correct, we actually make a change of variable, but it will do for illustrative purposes.
[tex]\int \frac{dN}{N} = -\lambda\int dt[/tex]
When we perform the integrals we obtain,
[tex]\ln(N) = \lambda t + const.[/tex]
We now exponentiate the equation,
[tex]N(t) = Ae^{-\lambda t}[/tex]
Where A is an arbitrary constant. We can fix this constant be saying that at t=0, we have a set number of radioactive nuclei, that is [itex]N(0) = N_0[/itex]. Hence, we obtain the radioactive decay law,
[tex]N(t) = N_0e^{-\lambda t}[/tex]
I'll address your additional questions in the next post, I just wanted to post this to make sure that I didn't lose it.
The decay of a radioactive substance is proportional to the number of atoms in the substance.
[tex] -\frac{dN}{dt} = \lambda N [/tex]
The solution of the differential equation is:
[tex] N=N_0 e^{-\lambda t}[/tex]
The half life is defined to be the time it takes for half the nuclei to decay therefore:
[tex] \frac{N}{N_0} = \frac{1}{2} = e^{-\lambda T_{1/2}} [/tex]
Now to get the [itex] \lambda T_{1/2} [/itex] we have to take the inverse exponential function of both sides which is the natural logarithm, [itex] \ln [/tex].
[tex] \ln \left(\frac{N}{N_0}\right) = -\lambda T_{1/2} [/tex]
[tex] T_{1/2} = - \frac{\ln \left(\frac{1}{2}\right)}{\lambda} [/tex]
thus, [tex] T_{1/2} = \frac{\ln (2)}{\lambda} [/tex]
The last part comes from a property of logarithms where:
[tex] \ln \left(\frac{1}{a}\right) = - \ln (a) [/tex]
EDIT: damn beaten to it! :-p
Now with respect to the half life, this is defined as the time taken for half the radioactive nuclei to decay, that is the time [itex]t = T_{1/2}[/itex] when [itex]N = N_0/2p[/itex]. So, we start from our exponential decay law we derived in the previous post;
And we set [itex]t=T_{1/2}[/itex] and [itex]N\left(T_{1/2}\right) = \frac{1}{2}N_0[/itex],
[tex]N\left(T_{1/2}\right) := \frac{1}{2}N_0 = N_0e^{-\lambda T_{1/2}}[/tex]
We divide through by [itex]N_0[/itex] and take the logarithm,
[tex]\frac{1}{2} = e^{-\lambda T_{1/2}} \Rightarrow \ln\left(\frac{1}{2}\right) = - \lambda T_{1/2}[/tex]
And then solve for [itex]T_{1/2}[/itex],
[tex]T_{1/2} = -\frac{1}{\lambda}\ln\left(\frac{1}{2}\right)[/tex]
By the laws of logarithms we can take the "-1" up as an exponent of the logarithm to obtain the result you quoted in your OP,
[tex]T_{1/2} = \frac{\ln(2)}{\lambda}[/tex]
I hope that answered all your questions.
Edit: But you beat me to the final result Kurdt :-p
Good to have a couple of different perspectives though.
I agree, especially when I can't seem to get LaTeX working today
Thanks you two, I've read over that a few times and it is all slowly but surely slipping in, if I marked this thread as solved would it eventually be deleted as I may want to come back to it later for further reference.
No problem. I don't think that it would be deleted, I imagine it would be moved to the https://www.physicsforums.com/forumdisplay.php?f=67" if anything, but I'm not 100% sure so it may be worth a question in the Feedback forum.
I understand that N and A are proportional but I think of that as [tex]N \propto A[/tex] what do all those other letters symbolise?
A is the activity, which is the rate of decay of radioactive nuclei. In other words the activity is a measure of how fast the radioactive nuclei decay (the rate of change of N with time). Therefore, we can write,
[tex]A = -\frac{dN}{dt}[/tex]
This is the time derivative of the number of radio active nuclei and is the mathematical way to describe the rate of radioactive decay. However, as you correctly said [itex]A\propto N[/itex], therefore we can write,
[tex]A = -\frac{dN}{dt} \propto N[/tex]
or adding a constant of proportionality,
[tex]A = -\frac{dN}{dt} = \lambda N[/tex]
Which is the same as the expression we started with before.
Do you follow? I apologise if I seam to be patronising you, but I'm not sure how much mathematics you know.
Marking as solved doesn't delete the thread. We like to keep them so other people can reference them. It just helps HH's in the homework forums recognise which threads have been dealt with.
Related to Derivations of the Decay Constant Equation.
What is the decay constant equation and how is it derived?
The decay constant equation is a mathematical formula that describes the rate at which a radioactive substance decays. It is derived from the law of radioactive decay, which states that the rate of decay is proportional to the amount of radioactive substance present.
What is the significance of the decay constant equation?
The decay constant equation is significant because it allows scientists to predict the rate at which a radioactive substance will decay and determine the amount of time it will take for half of the substance to decay (known as the half-life).
What factors affect the decay constant?
The decay constant is affected by the type of radioactive substance, the initial amount of the substance, and the temperature and pressure of the environment. It is also affected by any external factors that can influence the stability of the atomic nucleus.
How is the decay constant equation used in practical applications?
The decay constant equation is used in a variety of practical applications, such as determining the age of fossils and artifacts through radiocarbon dating, monitoring and controlling nuclear reactions, and calculating the effectiveness of radiation therapy in medical treatments.
Are there any limitations to the decay constant equation?
While the decay constant equation is a useful tool in understanding radioactive decay, it does have limitations. It assumes that the decay rate remains constant over time, which may not always be the case. It also does not take into account any potential changes in the environment or external factors that could affect the rate of decay.
  • Other Physics Topics
