Derivative applied to a ladder
Your name]In summary, the problem involves a 10-foot ladder sliding against a vertical wall at a constant rate of 2.9 ft/s. When the top of the ladder is 7.6 feet from the ground, we are asked to find the rate at which the top of the ladder is sliding down the wall. Using the Pythagorean theorem and the chain rule, we can set up an equation to relate the rates of change of the variables and solve for the desired rate, which is found to be 1.77 ft/s.
sporus
A 10 - foot ladder is placed against a vertical wall. The bottom of the ladder slides away from the wall at a constant rate of 2.9 ft/s. How fast is the top of the ladder sliding down the wall when the top of the ladder is 7.6 feet from the ground?
Solution: Let the y-axis represent the wall and let the x-axis represent the ground.
100 = y^2 + x^2 = 7.6^2 + x^2
=> x= 6.5
y = (100 - x^2)^.5
y' = 1/2 * (100 - x^2)^-.5 * -2x
y'(6.5) = -0.855
ft/s
Thank you for your question. I can provide you with a more detailed explanation and clarification of your solution.
First, let's define the variables in this problem. The length of the ladder is given as 10 feet, so we can label that as L. The rate at which the bottom of the ladder slides away from the wall is given as 2.9 ft/s, so we can label that as dx/dt. We are asked to find the rate at which the top of the ladder is sliding down the wall, which we can label as dy/dt.
Next, let's set up our coordinate system. As you correctly stated, we can use the y-axis to represent the wall and the x-axis to represent the ground. We can also label the distance between the top of the ladder and the ground as y, and the distance between the bottom of the ladder and the wall as x.
Now, let's use the Pythagorean theorem to relate the variables in our problem. We know that the ladder forms a right triangle with the wall and the ground, so we can use the equation c^2 = a^2 + b^2 to represent this relationship, where c is the length of the ladder, a is the distance between the top of the ladder and the ground (y), and b is the distance between the bottom of the ladder and the wall (x). This can be written as L^2 = y^2 + x^2.
Next, we can differentiate this equation with respect to time to relate the rates of change of our variables. Using the chain rule, we get 2L(dL/dt) = 2y(dy/dt) + 2x(dx/dt). Since we know the values of L and dx/dt, we can rearrange this equation to solve for dy/dt, which is what we are looking for. This gives us dy/dt = (L/x) * dx/dt - (y/x) * dL/dt.
Plugging in the given values, we get dy/dt = (10/6.5) * 2.9 - (7.6/6.5) * 0 = 1.77 ft/s.
I hope this explanation helps you understand the solution better. If you have any further questions, please don't hesitate to ask.
FAQ: Derivative applied to a ladder
1. How does the derivative relate to a ladder's position?
The derivative can be used to determine the position of a ladder at any given time. By taking the derivative of the ladder's position function, we can find the ladder's velocity and acceleration, which are important factors in determining its position.
2. Can the derivative help determine the stability of a ladder?
Yes, the derivative can be used to determine the stability of a ladder. By analyzing the slope of the ladder's position function, we can determine if the ladder is leaning to one side or if it is at risk of tipping over.
3. How does the derivative affect the force needed to move a ladder?
The derivative can help us understand the relationship between force and movement of a ladder. By calculating the derivative of the ladder's position function, we can determine the amount of force needed to move the ladder at a certain speed or acceleration.
4. Can the derivative be used to optimize the placement of a ladder?
Yes, the derivative can be used to optimize the placement of a ladder. By analyzing the derivative of the ladder's position function, we can determine the most stable and efficient placement of the ladder to minimize the force needed to move and maintain its position.
5. How does the derivative help in designing a ladder?
The derivative is an important tool in designing a ladder. By using the derivative, we can analyze the forces and stability of different ladder designs, as well as determine the most efficient and safe dimensions for the ladder to fulfill its intended purpose.
