Derivative Calculation: f'(x) & Increase/Decrease
In summary, the x values are -1, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10. The function f(x) has a derivative that changes sign at the roots of the derivative, which are -1, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10.
headbang
Have a function
\(\displaystyle f(x)=4x^3-x^4\)
Found the x values are X -1, 0, 1, 2, 3 , 4,
f(Y) -5, 0, 3, 16, 27, 0
i Need to find \(\displaystyle f^{\prime}(x)\) and find where it incteases and decreases??\(\displaystyle f`(x)= 3*4x^2-4x^3=4x^2(3-x)\)
what to Next?
Typically, you use $f'(x)$ to find out where $f(x)$ increases and decreases, not where $f'(x)$ increases or decreases (they're very different things).
What I would do is find out where your derivative changes sign (candidates are the roots of the derivative). I map out the procedure like this:
1. Find out where the derivative is zero. Suppose this happens at $x=-1, 4, 9$.
2. Divide up the whole real line into pieces, depending on where the derivative is zero. In the example, we'd have four pieces: $(-\infty,-1), (-1, 4), (4, 9),$ and $(9,\infty)$.
3. For each interval generated in Step 2, sample the derivative once inside the interval. You only need to do this once, assuming you found your roots correctly. So, let's say we do $f'(-1), f'(0), f'(5),$ and $f'(10)$.
4. For each interval you sampled where the derivative is positive, you have an increasing function. For each interval you sampled where the derivative is negative, you have a decreasing function.
Does that make sense?
You are right that i have to use \(\displaystyle f^{\prime}(x)\) to find out where \(\displaystyle f\) increases and decreases. I still don't understand how to calculate this, to solve the problem.
You computed $f'(x)$ correctly! Go ahead and plug numbers into that derivative.
Follow step 1 of the procedure given by Ackbach above...find the critical numbers, that is, the roots of the derivative. These are the places at which the derivative may change sign. Note that roots of even multiplicity will not be such places. What do you conclude so far?
FAQ: Derivative Calculation: f'(x) & Increase/Decrease
1. What is a derivative?
A derivative is a mathematical concept that represents the rate of change of a function. It is the slope of a tangent line at a specific point on the function's graph.
2. How do you calculate a derivative?
The derivative of a function f(x) is denoted as f'(x) and is calculated using the formula f'(x) = lim h→0 [f(x+h) - f(x)]/h. This formula is known as the limit definition of a derivative.
3. What does f'(x) represent?
f'(x) represents the instantaneous rate of change of a function at a specific point. It tells us how much the output of the function is changing with respect to the input at that point.
4. How can you use f'(x) to determine if a function is increasing or decreasing?
If f'(x) is positive, it means that the function is increasing at that point. If f'(x) is negative, it means that the function is decreasing at that point. If f'(x) is equal to 0, it means that the function is neither increasing nor decreasing at that point.
5. What are some real-life applications of derivatives?
Derivatives have various applications in fields such as physics, economics, and engineering. They are used to calculate rates of change, optimize functions, and model real-life scenarios. For example, derivatives are used in physics to calculate velocity and acceleration, in economics to determine marginal cost and revenue, and in engineering to design efficient structures and systems.
