Derivative of a Log function: Y=ln( )
In summary, the original equation is Y = ln [ (x+1)^3/((x^2)-1)^(1/2) and the derivative is (3x-4)/((x^2)-1). However, the online derivative calculator gave a different answer of (2x-3)/((x^2)-1). The best approach to solving this question is to use the properties of ln and simplify the equation before taking the derivative.
xxclaymanxx
1. Given Y = ln [ (x+1)^3/((x^2)-1)^(1/2), find y'
2. I came out with the following answer to this question:
(3x-4)/((x^2)-1)
How ever, I typed the question into an online derivative calculator (to hopefully check my asnwer as I have no answer key, and want to make sure I'm on the right path), but it came up with a completely different answer:
(2x-3)/((x^2)-1)
Could anyone point me in the right direction...my answer worked out nicely: factored, canceled etc. but I'm worried its not correct.
Thanks for the check!
I'm not sure how you solved the question initially, but the best way to approach such a question is to use the properties of ln... in particular, remember that ln(a^n/b^k) = ln (a^n) - ln (b^k) and furthermore this is equal to n ln(a) - k ln(b)... Apply these same rules to the original equation and you will get a form that is extremely simple to take the derivative of, and the answer that the online derivative calculator gave you will become apparent :)
FAQ: Derivative of a Log function: Y=ln( )
What is the derivative of a natural logarithmic function?
The derivative of a natural logarithmic function, y = ln(x), is 1/x.
How do you find the derivative of a log function?
To find the derivative of a log function, you can use the power rule or the chain rule. For y = ln(x), the derivative is 1/x.
What is the significance of the derivative of a log function?
The derivative of a log function tells us the slope of the tangent line at any point on the curve. It also helps us find the rate of change of a logarithmic function.
Can the derivative of a log function be negative?
Yes, the derivative of a log function can be negative. This indicates that the function is decreasing at that point.
Are there any real-life applications of the derivative of a log function?
Yes, the derivative of a log function is used in various fields such as finance, biology, and physics. For example, it can be used to model population growth or to calculate interest rates in compound interest problems.
