Derivative of a^x with respect to x
  • MHB
  • Thread starter tmt1
  • Tags
    Derivative
In summary, when considering exponential functions with a base of a positive number, the derivative is modified by a constant factor of the natural logarithm of the base. This is because changing the base is equivalent to changing the exponent of the function by a linear factor. Therefore, investigating different bases is essentially the same as investigating how $e^{kx}$ behaves for different $k$. To test understanding, one can try to differentiate $f(x) = x^x$ using the chain rule and product rule.
tmt1
234
I thought that when y = a^x,
dy/dx= a^x
But I just read somewhere that it is in fact a^x lnx.
Which one is it?
Thanks!
dy/dx= a^x
Which one is it?
Thanks!
d/dx (e$^x) = e^x$
as a^x = e$^{ln a x}$ you can proceed
If:
$f(x) = a^x$ (for this to make sense, we require $a > 0$)
we can write:
$f(x) = (g \circ h)(x)$
where:
$h(x) = \ln(a)x$ <---this is just multiplication by a constant
$g(x) = e^x$
since:
$(g\circ h)(x) = g(h(x)) = g(\ln(a)x) = e^{\ln(a)x} = (e^{\ln(a)})^x = a^x$.
The CHAIN RULE then states:
$f'(x) = g'(h(x))h'(x)$.
Now:
$g'(x) = e^x$
$h'(x) = \ln(a)$
So:
$f'(x) = (e^{\ln(a)x})(\ln(a)) = a^x\ln(a)$
rather than the $a^x\ln(x)$ you posted.
In other words, when we change the "base" of an exponential function, we have to modify the derivative by a constant factor, and this constant factor is the (natural) logarithm of the base.
When considering "exponential growth", what we mean is that the rate of growth is directly proportional to the population:
$f(x) = kf'(x)$.
These functions are of the form:
$f(x) = Ae^{kx}$
If we write $k = \ln(b)$ for some positive number $b$ (we can always do this, since the range of $\ln$ is the entire real numbers), we see that:
$f(x) = Ae^{\ln(b)x} = Ab^x$
in other words, "changing the exponent" of an exponential function by a linear factor (it being a linear factor is important, here), is really the same thing as "changing the base".
So...it really doesn't make too much sense to investigate "different bases", since this is pretty much the same thing as investigating how $e^{kx}$ behaves, for different $k$.
A good "self-test" for seeing how well you understand all this, is to try to differentiate:
$f(x) = x^x$
(you will need to use the chain rule AND the product rule).
FAQ: Derivative of a^x with respect to x
What is the derivative of a^x with respect to x?
The derivative of a^x with respect to x is ln(a) * a^x, where ln(a) is the natural logarithm of a.
Why is the derivative of a^x important?
The derivative of a^x is important because it allows us to determine the rate of change of a^x with respect to x, which is useful in many applications such as finance, physics, and engineering.
How do you find the derivative of a^x with respect to x?
To find the derivative of a^x with respect to x, we can use the power rule, which states that the derivative of x^n is n * x^(n-1). In this case, n is equal to a^x, so the derivative is ln(a) * a^x.
Can the derivative of a^x be negative?
Yes, the derivative of a^x can be negative. This happens when a is less than 1, as ln(a) is negative. It means that the function is decreasing at that point.
Can the derivative of a^x be zero?
Yes, the derivative of a^x can be zero. This happens when a is equal to 1, as ln(1) is equal to 0. It means that the function is neither increasing nor decreasing at that point.
