Derivative of Exponential and Logarithmic Functions
In summary, the derivative of an exponential function with base <i>b</i> is <i>bx</i>ln<b>e</b>, where <i>e</i> is the natural logarithm base. The derivative of a logarithmic function with base <i>b</i> is equal to <i>1/x</i>ln<b>e</b>, where <i>e</i> is the natural logarithm base. Yes, the derivative of an exponential or logarithmic function can be negative depending on the value of <i>x</i>. The derivative rules for exponential and logarithmic functions are derived using the power rule and the chain rule. The derivative of exponential and logarithmic functions has many real-world applications
domyy
196
PROBLEM 1
Find slope of tangent line at (1,0)
g(x) = x2lnx
Solution:
g'(x) = (x2lnx)'
g'(x) = x2[1/x . (x)']
g'(x) = x2 . 1/x
g'(x) = x
M tan/(1,0) = 0
PROBLEM 2
Use implicit differentiation:
yex+ y2 = 7lny - x3
Solution:
(ex)(y') + 2y(y') - 7(y'/y) = -ye - 3x2
y'(ex + 2y - 7/y) = -yex - 3x2
y' = -yex - 3x2/(ex + 2y - 7/y)
domyy said:
PROBLEM 1
g(x) = x2lnx
Solution:
g'(x) = (x2lnx)'
g'(x) = x2 . 1/x
g'(x) = x
M tan/(1,0) = 0
PROBLEM 2
yex+ y2 = 7lny - x3
Solution:
Your derivative of ##x^2 \ln(x)## is wrong.
Thanks for the reply. That's why posted both problems. I want to understand why.
If the derivative of 7lny on the second problem is 7[(1/y . (y)']
then why x^2 ln(x) isn't = x^2[1/x . (x)'] ?
OHHHH I THINK I GOT IT! Am I supposed to use the product rule?
The derivative of 7 is zero, because 7 is a constant . x2 is not a constant.
Use the product rule.
Ok, if so...this is how I'd do it:
g(x) = x2lnx
g'(x) = (x2)(1/x) + (lnx)(2x)
g'(x) = x + 2xlnx
g'(x) = 1 + 2(1)ln(1)
g'(x) = x + 2ln1
g'(x) = 1 + 0 =1
Thanks a lot!
I have another question:
Is it wrong to solve the problem this way:
y = ln (√x3- 5)
y' = [(x3 - 5)1/2]'/[x3 - 5]
y' = 1/2(x3 - 5)-1/2 (x3 - 5)'/ (x3 - 5)
y' = 3x2/ 2[(√x3 - 5)(√x3 - 5)]
y' = 3x2/ 2(x3 - 5)
Instead of:
y = ln (x3 - 5)1/2 = 1/2 ln (x3 - 5)
y' = 1/2 . (x3 - 5)'/(x3 - 5)
y' = 3x2/2(x3 - 5)
Can I solve it either way or could the first method cause me further problems with other exercises?
y = ln (√x3- 5)
y' = 3x2/ 2(x3 - 5)
Instead of:
y' = 3x2/2(x3 - 5)
It's best to start a new thread for a new problem.
Also, use sufficient parentheses.
√(x3-5) ≠ √x3-5 .​
As for your question: Either method is fine, but writing ln(ur) as (r)ln(u) reduces the number of times you need to use the chain rule.
Related to Derivative of Exponential and Logarithmic Functions
1. What is the derivative of an exponential function?
The derivative of an exponential function with base b is bxlne, where e is the natural logarithm base.
2. How do you find the derivative of a logarithmic function?
The derivative of a logarithmic function with base b is equal to 1/xlne, where e is the natural logarithm base.
3. Can the derivative of an exponential or logarithmic function be negative?
Yes, the derivative of an exponential or logarithmic function can be negative depending on the value of x. The derivative will be negative if x is less than 1 for an exponential function or if x is less than 0 for a logarithmic function.
4. How are the derivative rules for exponential and logarithmic functions derived?
The derivative rules for exponential and logarithmic functions are derived using the power rule and the chain rule. The power rule states that the derivative of x^n is nx^(n-1), and the chain rule states that the derivative of f(g(x)) is f'(g(x))g'(x). By applying these rules to the exponential and logarithmic functions, we can derive their respective derivative rules.
5. What are some real-world applications of the derivative of exponential and logarithmic functions?
The derivative of exponential and logarithmic functions has many real-world applications, including modeling population growth, analyzing financial data, and calculating rates of change in various scientific fields. It is also used in physics to study exponential decay and in chemistry to determine reaction rates. Additionally, the derivative of logarithmic functions is used in signal processing and engineering to analyze signals and design systems.
