Derivative of Exponential Function
In this case, it is a\lim_{h\to0} \frac{a^h-1}{h}. However, for the exponential function, the derivative is always equal to itself at any given x, as you mentioned. But the limit at x = 0 gives us the constant Ca, which, in a way, is a "generalized" derivative at 0 that takes into account the varying values of a in f(x) = ax.
Bashyboy
1,421
I am reading the about the derivative of an exponential function using the limit definition, but one step I don't quite understand: [itex]lim_{h\rightarrow0}\frac{a^h -1}{h} = f'(0)[/itex] Wouldn't that limit equal 0/0?
Every derivative limit is of the form "0/0" but, of course, the limit itself is NOT "0/0".
Oh, yes, how could I be so foolish to forget. Well, what sort of algebraic manipulation am I to perform then?
Have you defined the exponential function as [itex]\sum\frac{z^n}{n!}[/itex]. If so, use that to prove the limit.
There's the rub! It depends, of course, upon how you define [itex]e^x[/itex].
Many modern Calculus texts first define [itex]ln(x)= \int_a^x dx/x[/itex] and then define [itex]e^x[/itex] as the inverse function so your question never arises. That's my preferred method.
Robert1986 suggests that you define [itex]e^x[/itex] as as power series. That's perfectly reasonable, and again, your question does not arise.
But it is probably most common to define [itex]a^x[/itex] by first defining [itex]a^n[/itex] by "a multiplied by itself n times" then extending to all real numbers by requiring that [itex]a^{n+m}= (a^n)(a^m)[/itex], [itex](a^n)^m= a^{mn}[/itex], and continuity. Using that definition, we have
[tex]\frac{f(x+h)-f(x)}{h}= \frac{a^{x+h}- a^x}{h}= \frac{a^xa^h- a^x}{h}[/tex]
[tex]= \frac{a^x(a^h- 1)}{h}= a^x\frac{a^h- 1}{h}[/tex]
So that
[tex]\frac{da^x}{dx}= \lim_{h\to 0}\frac{a^{h+1}- a^x}{h}= a^x\lim_{h\to 0}\frac{a^h- 1}{h}[/tex]
is just [itex]C_aa^x[/itex] where [itex]C_a[/itex] is that limit.
It is easy to show that if 0< a< 1, then [itex]C_a[/itex] is negative, that [itex]C_2[/itex] is less than 1, that [itex]C_3[/itex] is greater than 1, and that [itex]C_a[/itex] continuously increases as a increases. That means that there must exist some value of a, between 2 and 3, such that [itex]C_a= 1[/itex] and we define "e" to be that value of a.
From [itex]\lim_{h\to 0}\frac{e^h- 1}{h}= 1[/itex] we can say that, for h close to 0, [itex]\frac{e^h- 1}{h}[/itex] is close to 1 so that [itex]e^h- 1[/itex] is close to h. Then [itex]e^h[/itex] is close to 1+ h and so e is close to [itex](1+ h)^{1/h}[/itex] which is common limit definition of e: [itex]e= \lim_{h\to 0}(1+ h)^{1/h}[/itex] or, taking n= 1/h, [itex]e= \lim_{n\to\infty} (1+ 1/n)^n[/itex].
@HallsOfIvy:
So this constant you are speaking about is the same as f'(0)?
Edit:
Also, the books says that this limit is the value of the derivative at zero. Why is that? And since the derivative of an exponential function itself, wouldn't that always be equal to one?
Bashyboy said:
@HallsOfIvy:
It's not; f'(0) is the derivative of f(x) evaluated at x = 0. The constant Ca, in a way, turns out to be a "function" of a that changes the value of f'(0) depending on the value of a in f(x) = ax.
Edit:
If f(x) = ax, then the difference quotient for f(x) is[tex]\frac{a^{x+h} - a^x}{h} = a^x\frac{a^h - 1}{h}[/tex]
At x = 0, the difference quotient turns out to be (ah - 1)/h, and taking the limit as h→0 gives the derivative at 0, written as f'(0).
FAQ: Derivative of Exponential Function
What is the derivative of an exponential function?
The derivative of an exponential function is the function's rate of change at a specific point. It represents the slope of the tangent line to the curve at that point.
How do you find the derivative of an exponential function?
To find the derivative of an exponential function, you can use the formula f'(x) = a^x * ln(a), where 'a' is the base of the exponential function. You can also use the power rule, which is applicable to functions in the form f(x) = a^x, where a is a constant.
What is the relationship between the derivative of an exponential function and the original function?
The derivative of an exponential function is equal to the original function multiplied by the natural logarithm of the base of the exponential function. In other words, the derivative of an exponential function is a constant multiple of the original function.
Why is the derivative of an exponential function always positive?
The derivative of an exponential function is always positive because the exponential function is always increasing. This means that the slope of the tangent line to the curve is always positive, resulting in a positive derivative.
What real-world applications use the derivative of an exponential function?
The derivative of an exponential function is used in various fields such as finance, economics, physics, and engineering. Some examples include compound interest, population growth, radioactive decay, and electrical circuits.
