Derivative of inverse tangent function
In summary: In post #5 it looks like it is a function of $x$. Try to be more specific about what you think is going on.
karush
MHB
3,269
Find the derivative of the function $f(y)$
$$f(y)=\tan^{-1}\left({8{y}^{3}+1}\right)$$
$$y=\tan^{-1}(x)$$
$$\tan(y)=x$$
$$y'\sec^2(y)=1$$
$$y'=\dfrac{1}{\sec^2(y)}$$
$$y'=\dfrac{1}{1+\tan^2(y)}$$
$$y'=\dfrac{1}{1+x^2}$$
For your problem (chain rule):
$$\dfrac{df(g(y))}{dy}=\dfrac{g'(y)}{1+(g(y))^2}$$
Some explanation to these formulas would be helpful to someone who is "clueless", for example, how you derive $y'\sec^2(y)=1$ from $\tan(y)=x$. Also, what exactly are $f$ and $y$ in the last equation?
\dfrac{df(y)}{dy}=\dfrac{f'(y)}{1+(f(y))^2}
Do you mean the following?
\dfrac{d\tan^{-1}(f(y))}{dy}=\dfrac{f'(y)}{1+(f(y))^2}
But then this redefines $f$ because in post #1 $f(y)=\tan^{-1}(8y^3+1)$ and here $f(y)=8y^3+1$.
karush, you can refer to the list of derivatives of trigonometric functions in Wikipedia. This article explains how to find $(\tan^{-1}(x))'$. In the future, it would help if you explain what exactly you don't understand. In this case, it is not clear whether you know the chain rule or you need the derivative of $\tan^{-1}(x)$ and, if you need the latter, whether you can look it up or need to derive it as a derivative of inverse function.
Yes; I've edited my post to reflect your correction. Thanks for the catch!
$$ \frac{8y'{y}^{3}+{y}^{'}}{(8y^2 +1)^2+1} =
\dfrac{24y^2}{\left(8y^3+1\right)^2+1}
The right-hand side is a correct answer; the left-hand side is not.
thus ??
$$ \dfrac{\class{steps-node}{\cssId{steps-node-4}{8\cdot\class{steps-node}{\cssId{steps-node-6}{\tfrac{\mathrm{d}}{\mathrm{d}y}\left[y^3\right]}}+\class{steps-node}{\cssId{steps-node-5}{\tfrac{\mathrm{d}}{\mathrm{d}y}\left[1\right]}}}}}{\left(8y^3+1\right)^2+1}
Yes, I don't know how else you could get the right-hand side in post #5.
I thoght $y'$ Was the same as $\d{}{y}$
No. y is still a function of x. Thus y' = dy/dx
-Dan
In post #1 $y$ looks like an independent variable.
FAQ: Derivative of inverse tangent function
What is the derivative of the inverse tangent function?
The derivative of the inverse tangent function, also known as arctan or tan^-1, is 1/(1+x^2).
How do you find the derivative of the inverse tangent function?
To find the derivative of the inverse tangent function, you can use the quotient rule or the chain rule. The quotient rule is generally easier to use and involves taking the derivative of the top function, multiplied by the bottom function, minus the top function multiplied by the derivative of the bottom function, all divided by the bottom function squared. Using the chain rule, you would first rewrite the inverse tangent function as (tan^-1(x))^2 and then take the derivative using the power rule and chain rule.
What is the domain of the inverse tangent function?
The domain of the inverse tangent function is all real numbers, excluding -1 and 1. This is because the tangent function has vertical asymptotes at these points, and the inverse tangent function is undefined at these points.
What is the range of the inverse tangent function?
The range of the inverse tangent function is from -π/2 to π/2, or -90 degrees to 90 degrees. This is because the tangent function has a period of π, and the inverse tangent function is the reflection of this graph over the line y=x.
What is the relationship between the derivative of the inverse tangent function and the derivative of the tangent function?
The derivative of the inverse tangent function is the reciprocal of the derivative of the tangent function. In other words, the derivative of the inverse tangent function is equal to 1/(derivative of tangent function). This relationship can be seen by using the chain rule and taking the derivative of tan^-1(x) as (tan^-1(x))^2.
