MHD93
- 93
Why is dp/dt = F even if the mass is changing, can it be derived from Newton's second law?
Mohammad_93 said:Why is dp/dt = F even if the mass is changing, can it be derived from Newton's second law?
Momentum is a measure of an object's motion, calculated as the product of its mass and velocity. It is a vector quantity, meaning it has both magnitude and direction.
The formula for momentum is p = mv, where p is momentum, m is mass, and v is velocity. It can also be written as p = mΔv, where Δv is the change in velocity over time.
Force is directly proportional to the rate of change of momentum. This means that if force is applied to an object, its momentum will change at a constant rate. Mathematically, this can be represented as F = dp/dt, where F is force, p is momentum, and t is time.
The derivative of momentum is calculated using the chain rule of calculus. This involves taking the derivative of the product of an object's mass and velocity, which results in the derivative of momentum being equal to the mass multiplied by the derivative of velocity with respect to time.
This is because, as mentioned earlier, force is directly proportional to the rate of change of momentum. In other words, the derivative of momentum is equal to the applied force. This relationship is fundamental in understanding the dynamics of objects in motion and is a key concept in physics.
