Derivative of Sine Function Raised to An Exponent
In summary, the derivative of (sin x) ^ ((sin(sin x))) can be found using logarithmic differentiation. By substituting u = sin x and using the chain rule, the derivative is equal to u^((sin u)-1)* (sin (u) + ((u)(ln u)(cos u))) multiplied by du/dx.
Justabeginner
309
Find the derivative of (sin x) ^ ((sin(sin x)))
I get sin(sin x) * [(sin x) ^ {(sin(sinx)-1)}* cos x] The cos x isn't part of the exponent
Is this right? Thanks :)
No, I think it' more complicated than that. First, I would substitute y = sin(x), and use df/dx = df/dy dy/dx. The tricky part is df/dy. For that, try rewriting f(y) as e^(ln f(y)).
This is what I have:
u= sin x
du= cos x
f(u) = u ^(sin u) du
f'(u)= u^((sin u)-1)* (sin (u) + ((u)(ln u)(cos u)))
And then just substitute sin x in for u?
u= sin x
du= cos x
Almost. You have computed df/du ok, but you need df/dx. You mention du = cos(x) (properly, du = cos(x)dx), so maybe you hadn't really forgotten that.
I would use logarithmic differentiation. If [itex]f(x)= (sin(x))^(sin(sin(x))[itex], then [itex]ln(f(x))= sin(sin(x))ln(sin(x)).
Now use the product rule and chain rule to find f'(x)/f(x).
Using the logrithmich method would make the problem easier. Try it, as suggested by one more post
I'm really confused as to what df/dx would be. If u= sin x, do I rearrange to get the value of x?
Hint: df/dx = (df/du)*(du/dx). This is called chain rule.
You better use that lograthmic method, it would be easier. Take
In post #3 you can see that Justabeginner has already cracked that part to obtain df/du. All that remains is to use the chain rule, i.e. multiply by du/dx.
No, he hasn't. What he had in post #3 was completely wrong.
In particular, the derivative of [itex]u^{f(u)}[/itex] is NOT [itex]u^{f(u)-1}f'(u)[/itex]
Instead, taking log of both sides of [itex]y= u^{f(u)}[/itex] gives [itex]ln(y)= f(u)ln(u)[/itex] and differentiating both sides of that, with respect to u, [itex]\frac{1}{y}\frac{dy}{du}= f'(u) ln(u)+ \frac{f(u)}{u}[/itex], [itex]\frac{1}{u^{f(u)}}\frac{dy}{du}[/itex][itex]= f'(u)ln(u)+ \frac{f(u)}{u}[/itex], [itex]\frac{dy}{du}= u^{f(u)}(f'(u)ln(u)+ \frac{f(u)}{u}[/itex]
That isn't what he did.
which he wrote as
[itex]\frac{dy}{du}= u^{f(u)-1}(uf'(u)ln(u)+ f(u))[/itex]
which he wrote as
This is the train of thought that I was using as I solved for f'(u).
And to finish off I'd just multiply f'(u) by du?
By du/dx. Maybe that's what you meant.
Yes sir, that's what I meant. Thank you very much :)
FAQ: Derivative of Sine Function Raised to An Exponent
What is the general formula for finding the derivative of a sine function raised to an exponent?
The general formula for finding the derivative of a sine function raised to an exponent is d/dx[sinn(x)] = n*sinn-1(x)*cos(x), where n is the exponent.
How do you apply the chain rule when finding the derivative of a sine function raised to an exponent?
When applying the chain rule, you first take the derivative of the outer function, which is sinn(x). Then, you multiply it by the derivative of the inner function, which is n*sinn-1(x)*cos(x), giving you the final formula d/dx[sinn(x)] = n*sinn-1(x)*cos(x).
Can the exponent in a sine function be a negative number?
Yes, the exponent in a sine function can be a negative number. In this case, the derivative formula becomes d/dx[sin-n(x)] = -n*sin-n-1(x)*cos(x).
What is the derivative of a sine function raised to the power of 1?
The derivative of a sine function raised to the power of 1 is simply cos(x).
Can the exponent in a sine function be a fraction?
Yes, the exponent in a sine function can be a fraction. In this case, the derivative formula would involve using the power rule as well as the chain rule.
