Derivative of the deformation gradient w.r.t Cauchy green tensor
In summary, the conversation discusses the derivative of the deformation gradient F with respect to the Cauchy Green Tensor C, where C is defined as F'F and ' denotes the transpose. The speaker also mentions using Google Translate to translate the Wikipedia page on deformation tensors in a language of their choice.
feynman1
435
29
What's the derivative of deformation gradient F w.r.t cauchy green tensor C, where C=F'F and ' denotes the transpose?
fresh_42 said:
Open https://de.wikipedia.org/wiki/Verzerrungstensor with Chrome and let Google translate it into a language of your choice.
very helpful but it doesn't answer my question directly
Are you trying to find the derivative of the CG tensor with respect to time in terms of the time derivatives of the deformation gradient tensor and its transpose?
no, but of F w.r.t C
FAQ: Derivative of the deformation gradient w.r.t Cauchy green tensor
What is the definition of the derivative of the deformation gradient with respect to the Cauchy green tensor?
The derivative of the deformation gradient with respect to the Cauchy green tensor is a mathematical concept that describes the rate of change of the deformation gradient with respect to changes in the Cauchy green tensor. It is essentially a measure of how the deformation gradient responds to changes in the Cauchy green tensor.
Why is the derivative of the deformation gradient with respect to the Cauchy green tensor important in mechanics?
The derivative of the deformation gradient with respect to the Cauchy green tensor is important in mechanics because it helps us understand how materials deform and behave under different conditions. It is a key component in the study of elasticity and plasticity of materials.
How is the derivative of the deformation gradient with respect to the Cauchy green tensor calculated?
The derivative of the deformation gradient with respect to the Cauchy green tensor is calculated using mathematical techniques such as the chain rule and tensor calculus. It involves taking partial derivatives of the deformation gradient components with respect to the Cauchy green tensor components.
What are some applications of the derivative of the deformation gradient with respect to the Cauchy green tensor?
The derivative of the deformation gradient with respect to the Cauchy green tensor has many applications in fields such as solid mechanics, material science, and engineering. It is used in the analysis and design of structures, predicting material behavior under different loading conditions, and developing constitutive models for materials.
Are there any limitations or assumptions when using the derivative of the deformation gradient with respect to the Cauchy green tensor?
Yes, there are some limitations and assumptions when using the derivative of the deformation gradient with respect to the Cauchy green tensor. It assumes that the material is homogeneous, isotropic, and undergoes small deformations. It also assumes that the material is in a state of mechanical equilibrium.
