Derivative Problem: when does f(x)=-f'(x)
  • MHB
  • Thread starter SGR
  • Tags
    Derivative
In summary: Ce^{-x}=c_1e^{-C}=0In summary, when the derivative of a function equals the function itself, you get the trivial solution.
SGR
What function equals the negative derivative of itself?
f(x) = -f'(x)
Re: Derrivative Problem: when does f(x)=f'(x)
Hello, and welcome to MHB! (Wave)
SGR said:
What equation equals the negative derivative of its self?
f(x) = f'(x)
Do you mean:
\(\displaystyle f(x)=-f'(x)\) ?
YES! when does f(x) = -f'(x)??
Let's use the notation of Leibniz and write:
\(\displaystyle \d{f}{x}=-f(x)\)
Now what if we separate variables and write:
\(\displaystyle \frac{1}{f(x)}\,df=-dx\)
We have divided by $f(x)$, and in doing so potentially eliminated the trivial solution $f(x)=0$, and so we need to be mindful of this in case the non-trivial solution does not include this.
What do you get when you integrate both sides of the above equation?
I don't know how to integrate.
You haven't studied integration yet?
Re: Derivative Problem: when does f(x)=f'(x)
Hi SGR and welcome to MHB.
Do you know how to differentiate and that $e^x$ is its own derivative?
If so, consider
$$y=e^{-x}$$
If we integrate, we get:
\(\displaystyle \ln|f(x)|=C-x\)
This implies:
\(\displaystyle f(x)=\pm e^{C-x}=\pm e^Ce^{-x}\)
Now, let \(\displaystyle c_1=\pm e^{C}\) and also let $c_1=0$ (reintroducing the trivial solution we lost when separating variables) and we have $c_1\in\mathbb{R}$:
\(\displaystyle f(x)=c_1e^{-x}\)
FAQ: Derivative Problem: when does f(x)=-f'(x)
What is a derivative problem?
A derivative problem is a type of mathematical problem that involves finding the rate of change of a function at a specific point. This rate of change is called the derivative and is denoted by f'(x).
What does it mean when f(x)=-f'(x)?
When a function f(x) is equal to the negative of its derivative f'(x), it means that the function is decreasing at a constant rate. This can also be interpreted as the slope of the function being negative at all points.
How do you solve a derivative problem when f(x)=-f'(x)?
To solve a derivative problem when f(x)=-f'(x), we can use the power rule, product rule, quotient rule, or chain rule to find the derivative of the function. Then, we can set the derivative equal to the negative of the original function and solve for x.
What is the significance of f(x)=-f'(x) in real-world applications?
In real-world applications, f(x)=-f'(x) can represent situations where a quantity is decreasing at a constant rate. For example, it can represent the rate of decay of a radioactive substance or the cooling rate of an object.
Can a function have multiple points where f(x)=-f'(x) is true?
Yes, a function can have multiple points where f(x)=-f'(x) is true. In fact, for any constant value of k, the function f(x) = -kx will satisfy this condition for all values of x. Additionally, some more complex functions may have multiple points where f(x)=-f'(x) is true.
