Derivative: Simplifying an Equation
  • MHB
  • Thread starter needOfHelpCMath
  • Tags
    Derivative
In summary, the given equation simplifies to become {12x^4+36x^2+48x-9}frac{4\left(2x^3+3x+2\right)^\frac{3}{2}}\frac{12x\sqrt{2x^3+3x+2}-\dfrac{\left(6x^2+3\right)^2}{2\sqrt{2x^3+3x+2}}}{2\left(2x^3+3x+2\right)}. This is achieved by cancelling out common factors and using the FOIL method on the left side.
needOfHelpCMath
72
How does this equation:
\(\displaystyle \dfrac{12x\sqrt{2x^3+3x+2}-\frac{\left(6x^2+3\right)^2}{2\sqrt{2x^3+3x+2}}}{2\left(2x^3+3x+2\right)}\)
becomes this equation
\(\displaystyle {12x^4+36x^2+48x-9}frac{4\left(2x^3+3x+2\right)^\frac{3}{2}}\)
\(\displaystyle \frac{12x\sqrt{2x^3+3x+2}-\dfrac{\left(6x^2+3\right)^2}{2\sqrt{2x^3+3x+2}}}{2\left(2x^3+3x+2\right)}\cdot\frac{2\sqrt{2x^3+3x+2}}{2\sqrt{2x^3+3x+2}}=\frac{24x(2x^3+3x+2)-(6x^2+3)^2}{4\left(2x^3+3x+2\right)^{\frac{3}{2}}}=\frac{48x^4+72x^2+48x-36x^4-36x^2-9}{4\left(2x^3+3x+2\right)^{\frac{3}{2}}}=\frac{12x^4+36x^2+48x-9}{4\left(2x^3+3x+2\right)^{\frac{3}{2}}}\)
ahh okay i see it now cancels out then foil for the left side then. thank you
FAQ: Derivative: Simplifying an Equation
What is a derivative?
A derivative is a mathematical concept that represents the rate of change of a function at a specific point. It is the slope of the tangent line at that point and can also be thought of as the instantaneous rate of change.
How do you simplify an equation using derivatives?
To simplify an equation using derivatives, you can use the rules of differentiation, such as the power rule, product rule, quotient rule, and chain rule. These rules allow you to find the derivative of each term in the equation and then combine them to simplify the overall equation.
Why is it important to simplify equations using derivatives?
Simplifying equations using derivatives can help us understand the behavior of a function and make it easier to solve problems involving that function. It can also help us find the maximum or minimum points of a function, which is useful in optimization problems.
Can all equations be simplified using derivatives?
No, not all equations can be simplified using derivatives. Some equations may be too complex or involve functions that cannot be differentiated using the standard rules. In these cases, other methods may need to be used to simplify the equation.
Are there any common mistakes to avoid when simplifying equations using derivatives?
One common mistake is to forget to apply the chain rule when differentiating composite functions. Another mistake is to use the wrong rule of differentiation for a specific term in the equation. It is important to carefully follow the rules and double-check your work when simplifying equations using derivatives.
