Derivative with several terms in denominator
In summary: A possible solution could involve expansion in powers of ##\epsilon##, followed by a minus sign. However, I am not sure if this is the right approach.
davidge
554
Hi. I want to solve [itex]\frac{\partial x^{\nu}}{\partial x^{\mu} + \xi ^{\mu}}[/itex], knowing that [itex]\frac{\partial x^{\nu}}{\partial x^{\mu}} = \delta ^{\nu}_{\mu}[/itex]. How can I do this?
What do ##\partial x^\nu## and ##\partial x^\mu## denote?
[itex]\partial[/itex] is the symbol for partial derivative and [itex]x^{\rho}[/itex] is the coordinate of a point [itex]x[/itex].
In that case the expression in the OP has no meaning. It is simply a misuse of the partial derivative symbol.
No. It is supposed to be a derivative. I must evaluate the derivative of [itex]x^{\nu}[/itex] with respect to [itex]x^{\mu}+ \xi^{\mu}[/itex].
In that case, there are necessary parentheses missing in the OP. It needs to be written
$$\frac{\partial x^\nu}{\partial (x^\mu+\xi^\mu)}$$
and ##x^\nu## needs to be specified as a function of ##x^\mu+\xi^\mu##. What is that function? Perhaps if you provided more information about the context of your question, the function would become apparent.
Stephen Tashi said:
Is it one of the types of derivatives treated in this Wikipedia article: https://en.wikipedia.org/wiki/Tensor_derivative_(continuum_mechanics) ?
I didn't notice any two or more terms in the denominator of those derivatives.
Yes. I'm sorry.
andrewkirk said:
xνxνx^\nu needs to be specified as a function of xμ+ξμxμ+ξμx^\mu+\xi^\mu. What is that function?
I was trying to relate the components of a vector in the new ##x## coordinates with that in the ##y## coordinates. They should change as $$V^{\nu}(x) = \frac{\partial x^{\nu}}{\partial (y^{\mu} = x^{\mu}+ \epsilon \xi^{\mu}(x))}V'^{\mu}(y).$$
There was missing the ##\epsilon## (|##\epsilon##| << 1) in the OP, because points ##y## and ##x## are very close from each other.
I found the solution for this derivative in books of GR. It involves expanding something, where one gets terms in higher orders in ##\epsilon##, there was also a minus sign. But can't remember more than this...
FAQ: Derivative with several terms in denominator
What is a derivative with several terms in the denominator?
A derivative with several terms in the denominator is a mathematical expression that represents the rate of change of a function with multiple terms in the denominator. It is used to calculate the slope of a curve at a specific point.
How do you find the derivative with several terms in the denominator?
To find the derivative with several terms in the denominator, you can use the quotient rule. This rule states that the derivative of a quotient is equal to the denominator times the derivative of the numerator minus the numerator times the derivative of the denominator, all divided by the square of the denominator.
Can you simplify the derivative with several terms in the denominator?
Yes, the derivative with several terms in the denominator can be simplified by factoring out common terms and simplifying the resulting expression. This can make the calculation easier and the final result more manageable.
Are there any special cases when finding the derivative with several terms in the denominator?
Yes, there are special cases when finding the derivative with several terms in the denominator. One example is when the denominator contains a variable raised to a negative power. In this case, the power rule can be used to simplify the derivative.
How is the derivative with several terms in the denominator used in real life?
The derivative with several terms in the denominator has many real-life applications, including physics, economics, and engineering. It can be used to calculate rates of change, such as velocity, acceleration, and growth rates, which are essential in understanding and predicting various phenomena in these fields.
