Derivatives and Integrals of units
In summary, when differentiating with respect to a variable, the units of the resulting derivative will have a factor of 1/[variable] and when integrating with respect to a variable, the units of the resulting integral will have a factor of [variable]. This follows from the definition of differentiation and integration, where the units of the function are divided or multiplied by the units of the variable.
Dougggggg
155
I couldn't decide whether to place this in the Physics or the Math section of the forums, deep down it is really a Math question for Physics problems. So mods please move if you feel it would be more appropriate in the Physics section.
So when doing calculations, I always like to make sure my units are behaving correctly. That I am not adding kg to m/s or something weird like that. One thing that I haven't really thought about how it applies is doing calculus type manipulation of units. Like if I take the derivative of a unit of displacement, with respect to a unit of time, I get a unit of displacement over time.
For Integrals if I take a integral of force, with respect to displacement, I get a unit of force times displacement.
Basically, what is the basic method to these kind of things?
Mathematics news on Phys.org
It is exactly as you say.
When you differentiate with respect to x, the units get a factor of 1/[x] (where [x] are x's units).
When you integrate with respect to x, the units get a factor of [x].
For differentiation, this follows simply from the definition, because f'(x) is a limit of the quotient
[tex]\frac{\Delta f(x)}{\Delta x}[/tex]
which has units
[tex]\frac{[\Delta f(x)]}{[\Delta x]} = \frac{[f(x)]}{[x]}[/tex].
For integration, simply reverse the argument, i.e. something along the lines of
[tex]\left[ \frac{d}{dx} \left( \int f(x) \, dx \right) \right] = [ f(x) ][/tex]
but it is also
[tex] \left[\int f(x) \, dx \right] / [x] [/tex]
therefore,
[tex] \left[ \int f(x) \, dx \right] = [f(x)] [x] [/tex].
Think of differentiation as being an extension of division and integration as an extension of multiplication.
The units of [itex]dy/dx[/itex] are the units of y divided by the units of x. For example, if y is measured in meters and x is measured in seconds then dy/dx (the rate of change of y with respect to x= rate of change of distance with respect to time) has units of "meters per second".
The units of [itex]\int f(x) dx[/itex] are the units of f(x) times the units of dx (which are the same as the units of x). For example, if f(x) is a "linear mass density" in "kilograms per meter" and x has units of meters, then [itex]\int f(x)dx[/itex] has units of (kilogram/meter)(meter)= kilogram.
FAQ: Derivatives and Integrals of units
What are derivatives and integrals of units?
Derivatives and integrals of units refer to the rate of change and the accumulation of units, respectively. They are mathematical concepts used to analyze and model the behavior of quantities that are measured in units, such as distance, time, and temperature.
Why are derivatives and integrals important in science?
Derivatives and integrals are important in science because they allow us to understand and predict the behavior of physical systems. For example, derivatives are used to calculate the velocity and acceleration of an object, while integrals can be used to determine the total distance traveled by the object.
What is the relationship between derivatives and integrals?
Derivatives and integrals are inverse operations of each other. This means that the derivative of a function is the integral of its rate of change, and the integral of a function is the derivative of its accumulated amount. This relationship is known as the Fundamental Theorem of Calculus.
How are derivatives and integrals calculated?
Derivatives are calculated using the rules of differentiation, which involve taking the limit of the rate of change of a function as the change in its independent variable approaches zero. Integrals are calculated using the rules of integration, which involve finding the area under a curve using a series of approximations.
In what fields of science are derivatives and integrals commonly used?
Derivatives and integrals are used in various fields of science, including physics, chemistry, biology, economics, and engineering. These concepts have applications in fields such as motion, energy, population growth, financial modeling, and signal processing.
