Are Integration and Differentiation True Opposites in Calculus?
In summary: There is no direct relationship between slope and area. Slope is simply a measure of how steep a function is, while area is the total enclosed space under the curve.
Swetasuria
48
What I have learned in school is that differentiation and integration are opposites.
By integrating a function we find the area under the graph. So, integration gives us the area. Differntiation gives slope of the function.
If I am right by saying differentiation and integration are opposites, then is area under the graph the opposite of the slope of the graph?
What dioes "opposite" mean??
Differentiation UNDO what indefinite integration does to a function f(x), that is:
Diff(Int(f(x))=f(x),
whereas indefinite integration UNDO, up to an arbitrary error constant, what differentiation did to the function f(x).
that is:
Int(Diff(f(x))=f(x)+some constant.
that is:
Pardon me if I sound stupid.
If we undo area under the graph, we get slope of that function then? Now I don't know how to undo the area or if that's even possible. Enlighten me.
no.
read what I wrote,
Swetsuria,
Notice that arildno said indefinite integration (no limits of integration). To get the area under the graph of a function, you use a definite integral.
The Fundamental Theorem of Calculus state in one of its two parts that differentiation and integration are essentially inverse operations.
$$\frac{d}{dx}\int_a^x f(t) dt = f(x)$$
Although the integral in this formula is a definite integral, due to the fact that one of the limits of integration is a variable (x), the integral represents a function of x.
What I did write, however, is closest precise interpretation of the vague and useless "opposite"-concept OP started out with..
That's why I wrote it like that.
OP is far too confused at present to tackle ideas of "area under of a graph" and "slope of the function".
The precisest meaning of "oppositeness" needs to be understood by him first.
When you subtract and add the same number, the two operations undo each other. When you multiply and divide by the same number, the two operations undo each other.
So would you consider addition and subtraction to be opposites? Would you consider multiplication and division to be opposites? Well, how come? The only simple answer is that they undo each other.
Well, indefinite integration and differentiation undo each other, so if that is your definition of "opposites" then yes, by all means consider them opposites. However, the word "opposites" is variable in meaning between different people, so maybe you should rephrase your question as:
"What is the intuitive reasoning behind differentiation and indefinite integration undoing each other?"
Well, by definition, indefinite integration is just the reverse of differentiation, so that would be your answer. A better question would be:
"Why does indefinite integration represent the rate of change of the area underneath a function?"
Well, this question is one that I've wondered many times myself. I'll let you know if I find out
Mark44 said:
Swetsuria,
Okay, so is there a relation betwwen the slope of curve and area under curve (if there is one, I mean)? I'm pretty confused here.:rolleyes:
This PDF has a great mathematical proof of the fundamental theorem of calculus on pg.61
http://www.matematica.net/portal/e-books/Riley,%20Hobson%20and%20Bence%20-%20Mathematical%20Methods%20for%20Physics%20and%20Engineering.pdf
FAQ: Are Integration and Differentiation True Opposites in Calculus?
1. What is the difference between a derivative and an integral?
A derivative represents the instantaneous rate of change of a function at a specific point, while an integral represents the cumulative effect of a function over an interval.
2. Why are derivatives and integrals important in mathematics?
Derivatives and integrals are important because they are fundamental concepts in calculus, which is used to analyze and model various real-world phenomena. They also have many practical applications in fields such as engineering, economics, and physics.
3. How are derivatives and integrals related?
The derivative and integral of a function are inverse operations of each other. The derivative of a function can be used to find the original function through integration, and the integral of a function can be used to find the rate of change through differentiation.
4. What are some common applications of derivatives?
Some common applications of derivatives include determining the slope of a curve, finding maximum and minimum values of a function, and analyzing the behavior of a function over time.
5. How are derivatives and integrals used in physics?
In physics, derivatives are used to calculate velocity and acceleration, while integrals are used to calculate displacement and total distance traveled. They are also used to analyze the motion of objects and predict future behavior.
