MHB Derivatives of symmetric expressions
The discussion revolves around finding clean expressions for the first and second derivatives of specific symmetric functions defined as products of rational expressions. The first function is given by f(x) = ∏(x-i)/(x+i), and the second by f(x) = ∏(x^2-i)/(x^2+i). A key relation is introduced, linking the derivative of the logarithm of f(x) to its derivative, allowing for simplification. The derivative of the logarithm for the first function is expressed as a summation involving the terms (1/(x-i) - 1/(x+i)). The same differentiation approach is applicable to the second function, indicating a method for deriving these expressions.
kalish1
So I was bored in math class and came up with this series of related questions, that I cannot answer:
Is there a clean expression for $f'(x),$ where $$f(x)=\prod_{i=1}^{n}\dfrac{(x-i)}{(x+i)}?$$
What about for $f''(x)?$ Or for $$f(x)=\prod_{i=1}^{n}\dfrac{(x^2-i)}{(x^2+i)}?$$
Mathematics news on Phys.org
You can use the relation...
$\displaystyle \frac{d}{d x} \ln f(x) = \frac{f^{\ '} (x)}{f(x)} \implies f^{\ '} (x) = f(x)\ \frac{d}{d x} \ln f(x)\ (1)$
... and in this case...
$\displaystyle \frac{d}{d x} \ln f(x) = \sum_{i = 1}^{n} (\frac{1}{x - i} - \frac{1}{x + i}) = 2\ \sum_{i=1}^{n} \frac{i}{x^{2} - i^{2}}\ (2)$
The same procedure is valid also for the second function...
Kind regards
$\chi$ $\sigma$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
