lo1206
- 2
The motion of various shaped objects that bob in a pool of water can be modeled by a second order differential equation derived from F = ma.
The forces acting on the object are:
1)force due to gravity,
2)a frictional force by water,
3)and a buoyant force based on Archimedes' principle: An object that is completely or partially submerged in a fluid is acted on by an upward force equals to the weight of the water it displaces.
Derive the ODE by:
1)the dependent variable is the depth z of the object's lowest point in water,take z to be negative downward so that z= -1 means 1 ft of the object has submerged.
2)Let V(z) be the submerged volume of the object
3)m be the mass of the object
4)p be the density of the water
5)g be the acceleration due to gravity
6)w be the coef of friction for water(friction is proportional to the vertical velocity of the object)
I am not sure whether my answer is correct since I had confusion in treating positive and negative sign.
z''+ (w/m)z'-(pVg)/m +g =0
Thx very much for your attention
