Derive differential equation that describes temperature
In summary, we are trying to derive a differential equation that governs the temperature distribution in a copper plate joined to a solar collector. To do this, we will use the energy balance equation and the different heat transfer equations for conduction, radiation, and convection. Careful consideration of all the terms and proper boundary conditions will lead to a second-order differential equation that can be solved using standard methods.
Shackleford
1,656
I'm taking an engineering heat transfer course as an elective.
1. Homework Statement
Copper tubing is joined to a solar collector plate of thickness t, and the working fluid maintains the temperature of the plate above the tubes at To. There is a uniform net radiation heat flux q”rad to the top surface of the plate, while the bottom surface is well insulated. The top surface is also exposed to a fluid at T that provides for a uniform convection coefficient h.
(a) Derive the differential equation that governs the temperature distribution T(x) in the plate.
(b) Obtain a solution to the differential equation for appropriate boundary conditions.
Conduction, convection, and radiation
I want to first analyze a differential control volume.
Ac = yt
As = ydx
qcond + qrad = qconv + qcond, x + dr
-kAcdT/dx + εσ[T4(x) - T4] ydx = h[T(x) - T] ydx + -kAcdT/dx -kd/dx(AcdT/dx)
Of course, t is constant and we're assuming that temperature does not vary with the y-coordinate. However, I wanted to start with an actual volume and see where y factors out. Am I on the right track?
Dear student,
Thank you for sharing your attempt at solving this problem. It seems like you are on the right track and have a good understanding of the different heat transfer mechanisms involved in this system.
To derive the differential equation that governs the temperature distribution T(x) in the plate, we can use the energy balance equation for a control volume as follows:
Σ(in) = Σ(out) + Σ(generation)
Assuming steady-state conditions and neglecting any internal heat generation, we can write the energy balance equation as:
Where qcond is the conduction heat transfer, qrad is the radiation heat transfer, and qconv is the convection heat transfer.
To solve for the temperature distribution, we can use the Fourier's law of heat conduction for the conduction heat transfer, the Stefan-Boltzmann law for the radiation heat transfer, and the Newton's law of cooling for the convection heat transfer. This will result in a second-order differential equation with appropriate boundary conditions that can be solved using standard methods.
I would recommend carefully reviewing the equations you have used and making sure that all the terms are accounted for and properly balanced. Also, it might be helpful to draw a control volume diagram to better visualize the problem and the different heat transfer mechanisms involved.
I hope this helps and good luck with your studies!
Related to Derive differential equation that describes temperature
1. What is a differential equation?
A differential equation is a mathematical equation that describes the relationship between a function and its derivatives. It is used to model various natural phenomena in science and engineering.
2. How is temperature related to a differential equation?
Temperature is a physical quantity that changes with respect to time and space. It can be described by a differential equation that relates temperature to its rate of change over time and its spatial variations.
3. What are the variables involved in the differential equation for temperature?
The variables involved in the differential equation for temperature are time, space, and temperature itself. The equation will also include constants that represent physical properties, such as thermal conductivity and heat capacity.
4. How is the differential equation for temperature derived?
The differential equation for temperature is derived using principles from thermodynamics and heat transfer. It involves applying conservation of energy and the laws of thermodynamics to a system, and then solving for the rate of change of temperature over time and space.
5. What are the applications of the differential equation for temperature?
The differential equation for temperature has various applications in fields such as physics, chemistry, and engineering. It is used to study heat transfer, thermodynamics, and other phenomena related to temperature changes in systems. It is also used in the design and analysis of thermal systems and devices.
