Derive Electric Potential Energy
In summary, the conversation discusses the problem of finding the potential energy of a point charge within a uniformly charged sphere with total charge Q and radius R. The formula for the potential energy is derived using the given variables and known equations, and it is shown that the potential energy varies with r according to the equation U(r) = Qq'/4*pi*epsilon*R * (3/2 - r^2/2R^2) when r is less than R. The conversation also addresses the issue of integrating from infinity to r in order to account for the potential energy at infinity being 0.
SpringPhysics
107
1. The problem statement, all variables and given/known
For a a uniformly charged sphere of radius R with total charge Q, show that the potential energy of a point charge q' varies with r
U(r) = Qq'/4[tex]\pi[/tex][tex]\epsilon[/tex]R * (3/2 - r2/2R2 if r < R
[tex]\Delta[/tex]U = - [tex]\int[/tex]E(r)q'dr cos[tex]\theta[/tex]
I used that the electric field of q' when r < R is Qr/4[tex]\pi[/tex][tex]\epsilon[/tex]R3. I tried to integrate from initial to final for r, but then I only get 1/2 as opposed to 3. I have no idea where the 3 comes from.
Can someone help please?
What did you take as the initial and final r's? You have to integrate from infinity to r because potential energies are always stated with the potential at infinity as 0. (Of course, the electric field outside the sphere is not E=kQr/R^3, which adds another complication.)
Ohh, I took the initial r to be R. Does that mean I have to add back the potential energy at R from infinity in order to get the expression for the potential energy at r when r < R?
Yes.
Thank you!
FAQ: Derive Electric Potential Energy
What is electric potential energy?
Electric potential energy is the energy that a charged object has due to its position in an electric field. It is a form of potential energy that can be converted into other forms of energy, such as kinetic energy, when the charged object moves.
How is electric potential energy calculated?
The formula for electric potential energy is U = qV, where U is the electric potential energy, q is the charge of the object, and V is the electric potential (also known as voltage). This formula assumes that the electric field is uniform.
What is the SI unit for electric potential energy?
The SI unit for electric potential energy is joule (J). However, it is often expressed in electron volts (eV) in the field of atomic and nuclear physics.
How does electric potential energy affect the movement of charged particles?
Charged particles will tend to move from areas of high electric potential energy to areas of low electric potential energy. This is because they will experience a force in the direction of decreasing potential energy, similar to how objects will roll down a hill to reach the lowest point.
Can electric potential energy be negative?
Yes, electric potential energy can be negative. This occurs when the charged object has a negative charge and is placed in an electric field with a positive potential. The negative sign indicates that the object would have to do work to move from its current position to a position with higher potential energy.
