Derive Radiation Pressure in terms of N, V, hf
The discussion focuses on deriving the radiation pressure exerted by a gas of photons using kinetic theory. The key variables include N photons, each with energy hf and momentum hf/c, in a perfectly reflecting environment. The momentum transferred to the wall is calculated as 2(hf/c), and the number of collisions is determined based on the photon wavelength and frequency. The force on the wall is derived from the number of collisions and momentum transfer, leading to an expression for pressure. The challenge lies in expressing the final result in terms of N, V, and the product hf, with suggestions to utilize the relationship c = λf for simplification.
duran9987
Compute the radiation pressure exerted by a gas of photons (according to kinetic theory). There are N photons, each with energy hf, the momentum is hf/c, and the walls are perfectly reflecting. Express the pressure in terms of N, V, and the product hf.
Pressure = (1/3)*(Nk/V) (mv^2) , where v^2 is an average
Pressure = Force / Area
Speed of Photons = λf
Force on Area A = (Number of collisions on the wall in time Δt)(Momentum transferred to the wall per collision)/(Δt)
The momentum transferred to the wall by the photons is 2(hf/c)
The number of collisions = ((λf)ΔtA)(1/2)(N/V)
Force on Area A = (hf/c)(A)(N/V)(λf)
Multiply both Sides by Area to get pressure = P = (1/3)h(f^2)λ(N/V)(1/c)
Not sure how to express it in terms of the product hf.
Use c=λf from the relevant equations?
  • · Replies 23 ·
