Derive Taylor Expansion of $f(x)$ Around x=0 Up to x^2
In summary, the first few terms in the Taylor expansion of $f(x) = \sqrt{1+\sin(x)}$ around $x=0$ are:$f(x) = 1 + \frac{x}{2} - \frac{x^2}{8} + R_2(x)$where the remainder term is given by:$R_2(x) = \frac{\sin^2(c) - 2\sin(c)\cos^2(c) - \cos^4(c)}{16(1+\sin(c))^{\frac{5}{2}}}x^3$
Guest2
193
Consider the function $f(x) =\sqrt{1 + \sin(x)}$. Derive the fi rst few terms in the Taylor expansion of $f(x)$ around $x = 0$, up to and including terms of order $x^2$. Give an explicit formula for the remainder term.
I can do the first part, but how do I find the remainder term?
To find the remainder term, we can use the Lagrange form of the remainder in Taylor's theorem. This states that the remainder term $R_n(x)$ for a function $f(x)$ with a Taylor polynomial of degree $n$ centered at $x=a$ is given by:
$R_n(x) = \frac{f^{(n+1)}(c)}{(n+1)!}(x-a)^{n+1}$
where $c$ is some number between $a$ and $x$. In this case, since we are finding the Taylor expansion around $x=0$, our formula becomes:
$R_n(x) = \frac{f^{(n+1)}(c)}{(n+1)!}x^{n+1}$
To find the remainder term for $f(x) = \sqrt{1 + \sin(x)}$, we first need to find the derivatives of this function. We can use the chain rule to find the derivatives of the inner function $1+\sin(x)$, which are:
$f'(x) = \frac{\cos(x)}{2\sqrt{1+\sin(x)}}$
$f''(x) = -\frac{\sin(x) + 2\cos^2(x)}{4(1+\sin(x))^{\frac{3}{2}}}$
$f'''(x) = \frac{3\sin^2(x) - 6\sin(x)\cos^2(x) - 2\cos^4(x)}{8(1+\sin(x))^{\frac{5}{2}}}$
Now, we can plug these derivatives into our formula for the remainder term, and since we are only interested in terms up to $x^2$, we will use $n=2$. This gives us:
$R_2(x) = \frac{f^{(3)}(c)}{3!}x^3 = \frac{\frac{3\sin^2(c) - 6\sin(c)\cos^2(c) - 2\cos^4(c)}{8(1+\sin(c))^{\frac{5}{2}}}}{3!}x^3$
We can simplify this to get our final formula for the remainder term:
FAQ: Derive Taylor Expansion of $f(x)$ Around x=0 Up to x^2
What is the Taylor Expansion of a function?
The Taylor Expansion of a function is a mathematical technique used to approximate a function using a series of simpler terms. It is often used to find the value of a function at a point where the function is difficult to evaluate directly.
What does it mean to derive a Taylor Expansion?
Deriving a Taylor Expansion means to find the coefficients of the terms in the expansion. This is done by taking the derivatives of the function at a given point and evaluating them at that point.
Why is the Taylor Expansion often calculated around x=0?
Calculating the Taylor Expansion around x=0, also known as the Maclaurin Expansion, is often done because it simplifies the calculations and allows for the use of known values for the derivatives at that point. It also makes the resulting series easier to work with.
What does it mean to derive a Taylor Expansion up to x^2?
Deriving a Taylor Expansion up to x^2 means that the expansion will include terms up to and including x^2. This means that the expansion will have three terms: the constant term, the linear term, and the quadratic term. Including more terms in the expansion will result in a more accurate approximation of the function.
How is the Taylor Expansion used in scientific research?
The Taylor Expansion is commonly used in scientific research to approximate complex functions and make them easier to work with. It is also used to find the values of functions at points where it is difficult to evaluate directly. Additionally, the Taylor Expansion is often used in mathematical models and simulations to make predictions and analyze data.
