Derive the equation of a line after x+(1/2)y =0 is mapped by T
In summary, Homework Statement states that somebody is on the last question of a set of practice examinations and is trying to solve an equation for a line onto which a line x+(1/2)y=0 is mapped.
Richie Smash
293
Hello hello, I am on the second to last question of 6 practice examinations I've been doing!
''There is a transformation matrix T =
\begin{pmatrix}
4 & 9\\
3& 4
\end{pmatrix}
They want me to derive the equation of the line onto which the line x +(1/2)y = 0 is mapped by the transformation T.
From x+1/2y=0
y= -2x
So first I rearranged the equation to solve for (Y) and got
y= -2x
So then I multiplied each element in the matrix by - 2x and got
\begin{pmatrix}
-8x & -18x\\
-6x& -8x
\end{pmatrix}
But this is confusing, they want the equation of the line, to be honest I don't know which direction to go here, do I now multiply this new Matrix by the original T?
I tried that and got
\begin{matrix}
-86x &-144x \\
-48x& -86x
\end{matrix}
I'm not sure which direction to take, as they want the equation of the line...
After the transformation to new coordinates (x', y'), you have an equation for each of x' and y' in terms of x. You should be able to write those two equations down and solve the simultaneous equations for y' in terms of x'.
Sorry, I'm not quite understanding what you're saying?
He is saying that the transformation gives
$$\begin{array}{l}
x' = 4x + 3y \\
y' = 9x+4y
\end{array}
If you know that ##y = -2x## you can figure out how ##x'## and ##y'## are related.
y= -2x
This line is generated by all constant multiples of the vector <1, -2>. The parametric form of this line would be <t, -2t>, for real numbers t. Your transformation matrix operates on vectors, and produces vectors as its outputs.
I'm not sure I understand this method, but here is something that I follow:
I take the knowledge that when x = 1 , y= -2, and when x=2, y= -4
I put these under the transformation and obtain the two images of the points (-14, -9) and (-28,-10)
I then find the gradient which is (1/14)x and substitute the gradient and one of the new image points into the equation y=mx +c
So I'd get c = -8
SO the final equation of the new line would be y=(1/14)x-8
You should check this answer back in your original equations. Since y = -2x, you know that the original line goes through x=0, y=0. The transformation will map that to x'=0, y'=0. Your answer for the new line does not go through (0,0), so it must be wrong.
Your general method is ok. The second point you used x=2, y=-2 is not correct. It should be x=2, y=-4.
Ah yes... you'r right, I am defeated by this question I'm afraid, I just don't knwo where to begin?
You're very close to getting the answer. Your general method is ok. The second point you used x=2, y=-2 is not correct. It should have been x=2, y=-4. Or you can use x=0, y=0, which may be simpler.
Likes Richie Smash
SOLVED :D
Likes FactChecker
Richie Smash said:
SOLVED :D
Before marking this thread as Solved, it would be helpful for you to give the solution.
Somebody may come along later and be interested in this question and its solution.
Ok well the solution was, because the original line goes through zero, I can use the two points (0,0) and (1,-2)
From here I ran them through the matrix and obtained the image points (0,0) (-14,-5)
I found the gradient for these points and then I used either point to sub into the equation of a straight line y=mx +c using my newly found gradient as well.
From here I calculated the equation of the line to be y=(5/14)x
Likes FactChecker
You should check the (-14, -9) point again. That looks wrong. I agree with your final answer, so I think that you just forgot to record a correction of that point.
fixed
From here I ran them through the matrix and obtained the image points (0,0) (-14,5)
Answer is OK, but you really should not use the same symbols (x,y) in both cases. The transformation gives a change of coordinates, from (x,y) to something else, such as (x', y'). You want the line in the NEW coordinate system, so it is y' = (5/14)x'. Never, use the exact same symbol for two different quantities in the same problem.
Likes FactChecker
Richie Smash said:
fixed
Nope. Still a problem. It's important to be careful -- almost machine-like on these calculations. You can see that if there are a long string of calculations, the odds of getting it correct all the way through depends on being very careful at each step.
UPDATE: Good. Post #12 now looks correct to me.
PS. The need to be so careful is why I turned to computer programming -- once you get the code right, the calculations are correct every time no matter how complicated and tricky they are.
Likes Richie Smash
Related to Derive the equation of a line after x+(1/2)y =0 is mapped by T
What is the equation of the line after being mapped by T?
The equation of the line after being mapped by T is y = -2x. This can be found by solving for y in the original equation x + (1/2)y = 0 and then applying the transformation T, which multiplies the x-value by -2.
How do you derive the equation of the line after being mapped by T?
To derive the equation of the line after being mapped by T, first solve for y in the original equation x + (1/2)y = 0. Then, apply the transformation T, which multiplies the x-value by -2. This will result in the equation y = -2x.
What is the significance of mapping a line by T?
Mapping a line by T allows us to see how the line changes when subjected to a transformation. It helps us understand how the line is affected by T and allows us to find the new equation of the line after the transformation.
Can T map any type of line?
Yes, T can map any type of line as long as it is a linear function. This includes horizontal, vertical, and diagonal lines.
Can T map a non-linear function?
No, T can only map linear functions. Non-linear functions have a different form and cannot be transformed using T.
  • Topology and Analysis
  • Linear and Abstract Algebra
