Derive the magnitude and direction of the linear acceleration
In summary, the problem asks for the magnitude and direction of the linear acceleration at the tip of a stick, ignoring the effect of gravity. The solution involves finding the x and y components of the velocity, taking the derivative to find the components of the acceleration, and recognizing that the magnitude of the acceleration is rω2. The direction of the acceleration can be shown by drawing a right triangle or by considering the vector from the tip to the center.
saltine
89
[Solved] Centripetal Acceleration
Derive the magnitude and direction of the linear acceleration at the tip of the stick, ignore the effect of gravity.
r = length of stick
a = dv/dt
I first find the x and y components of v, then I took the derivative to find ax and ay:
vx = rω cos(θ)
vy = rω sin(θ)
ax = rω ( -sin(θ) dθ/dt ) = rω ( -sin(θ) (-ω) ) = rω2 sin(θ)
ay = rω ( cos(θ) dθ/dt ) = rω ( cos(θ) (-ω) ) = -rω2 cos(θ)
I recognized that ω is -dθ/dt since it is in the opposite direction. This shows that the magnitude of a is rω2. If I were to draw the vector on the graph, it would also show that a is pointing toward the hinge.
But how would I show that a is always pointing toward the hinge?
Is this argument valid:
Let q be the a vector from the tip to the center, then
qx = sin(θ)
qy = -cos(θ)
Now, a • q = rω2cos(ф) = rω2, where ф is the angle between the two vectors and ф=0 in this case. Therefore a and q are in the same direction.
Is there a simpler way to show this?
- Thanks
Your solution is perfect.
Since the components of the acceleration vector are proportional to sin θ and -cosθ, you can also draw a right triangle to show that the acceleration vector points towards the center.
for providing the equations and your attempt at a solution. Your approach is correct, and your argument for the direction of the linear acceleration is valid. Another way to show that the linear acceleration is always pointing towards the hinge is to use the equation for centripetal acceleration, which is given by a = ω2r, where ω is the angular velocity and r is the radius of the circular motion. Since the stick is rotating at a constant angular velocity, the magnitude of the linear acceleration will also be constant at rω2. This means that the direction of the linear acceleration will always be towards the center of the circular motion, which is the hinge in this case.
Related to Derive the magnitude and direction of the linear acceleration
1. What is linear acceleration?
Linear acceleration is the rate of change of an object's velocity in a straight line. It is a vector quantity, which means it has both magnitude and direction.
2. How do you calculate the magnitude of linear acceleration?
The magnitude of linear acceleration can be calculated by dividing the change in velocity by the change in time. The formula is: a = (vf - vi) / t, where a is the acceleration, vf is the final velocity, vi is the initial velocity, and t is the time interval.
3. What is the unit of measurement for linear acceleration?
The unit of measurement for linear acceleration is meters per second squared (m/s²). This means that for every second an object is accelerating, its velocity increases by a certain number of meters per second.
4. How do you determine the direction of linear acceleration?
The direction of linear acceleration is determined by the direction of the change in velocity. If the velocity is increasing, the acceleration is in the same direction as the velocity. If the velocity is decreasing, the acceleration is in the opposite direction.
5. Can linear acceleration be negative?
Yes, linear acceleration can be negative. This indicates that the velocity is decreasing in the direction of motion, also known as deceleration. However, the magnitude of the acceleration is still calculated using the absolute value of the change in velocity.
9K
