Derive the nth term of a sequence
In summary, the speaker is asking for help in deriving a general equation for the nth term of a sequence, given an equation for the sum to the nth term. They suggest using a discrete example to understand the concept better. The speaker also asks for help in finding a specific term in terms of two sum equations. They then clarify that their previous blank reply was a way of saying thanks.
Aceix
49
How do i go about deriving a general eqn for the nth term of a sequence provided an eqn of the sum to the nth term is given in terms of n?
Mathematics news on Phys.org
Rather than give you the answer, try a discrete example. Think of it this way. I know:
Sum4 = a1+a2+a3+a4
and I know
Sum3 = a1+a2+a3 .
How would I find a4 in terms of Sum4 and Sum3?
Sum4 = a1+a2+a3+a4
and I know
Sum3 = a1+a2+a3 .
Does your blank reply mean you don't know?
i meant thanks.
Aceix.
OK. You're welcome.
Related to Derive the nth term of a sequence
1. What is the formula for finding the nth term of a sequence?
The formula for finding the nth term of a sequence is an = a1 + (n-1)d, where a1 is the first term in the sequence, n is the term number, and d is the common difference between terms.
2. How do I identify the pattern in a sequence to find the nth term?
In order to identify the pattern in a sequence, you should look for a consistent difference or ratio between terms. Once you have identified the pattern, you can use the formula an = a1 + (n-1)d to find the nth term.
3. Can the nth term of a sequence be negative?
Yes, the nth term of a sequence can be negative. This can occur if the common difference is a negative number or if the first term in the sequence is a negative number.
4. Do all sequences have a pattern and an nth term?
No, not all sequences have a pattern or an nth term. Some sequences may be random or have a complex pattern that is difficult to identify. In these cases, there may not be a simple formula to find the nth term.
5. Can I use the formula for finding the nth term of a sequence for any type of sequence?
The formula an = a1 + (n-1)d can be used for arithmetic and geometric sequences, which have a constant difference or ratio between terms. However, this formula may not apply to other types of sequences, such as Fibonacci or alternating sequences.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
