Deriving algebraic definition of cross product
In summary: Homework Equation: ##\vec {u} \times \vec {v} = |u||v|sin(\theta)\hat n####\hat n = \frac{\vec u \times \vec v}{|\vec u \times \vec v|}##In summary, the equation for the vector cross product is defined as ##\vec {u} \times \vec {v} = (u_2v_3 - u_3v_2)\hat i + (u_3v_1 - u_1v_3)\hat j +
member 731016
I am trying to derive the formula ##\vec {u} \times \vec {v} = (u_2v_3 - u_3v_2)\hat i + (u_3v_1 - u_1v_3)\hat j + (u_1v_2 - u_2v_1)\hat k ## because it is extremely difficult to commit to memory for my upcoming exam
So far, I have got the equations,
##u \cdot (\vec u \times \vec v) = 0##
##u_1a + u_2b + u_3c = 0##
##v_1a + v_2b + v_3c = 0##
Could some please give me some guidance?
Many thanks!
There used to be the indexing mnemonic xyzzy for x = yz - zy and the permutations of it yzxxz and zxyyx
But the easiest way is the determinant scheme
Code:
|    i    j    k  |
|   ax   ay   az  |
|   bx   by   bz  |
expanding the determinant over I j and k we get:
Code:
i | ay az |  - j | ax az | + k | ax ay |  = i (aybz-azby) - j (axbz-azbx) + k (axby-aybx)
  | by bz |      | bx bz |     | bx by |
NOTE: Pay attention to the minus sign on the j term
Likes WWGD, jtbell, topsquark and 3 others
Here's a video discussing it:
Likes WWGD, topsquark and member 731016
Alternatively, just remember [itex]\mathbf{e}_z = \mathbf{e}_x \times \mathbf{e}_y[/itex] together with the cyclic, anticommutative and distributive properties.
Likes robphy, topsquark, member 731016 and 1 other person
Why? There are some things that it's just better to memorize. Regarding the video that @jedishrfu posted, to evaluate a 3x3 determinant, you can break it down into three 2x2 determinants. It doesn't matter whether you go across a row or down a column. If you're expanding the "pseudo-determinant" of a cross product, it's probably simpler to expand across the top row.
##\begin{vmatrix} i & j & k\\a & b & c\\d & e & f \end{vmatrix}
=i\begin{vmatrix}b& c\\e & f\end{vmatrix} - j\begin{vmatrix}a& c\\d & f\end{vmatrix} + k \begin{vmatrix}a& b\\d & e\end{vmatrix}##
The important things to remember are:
  1. Each 2x2 sub-determinant is made up of the terms not in the same row or column as the multiplier. For example, the first sub-determinant above consists of the terms of the 3x3 determinant that aren't in row 1 and column 1.
  2. The signs of the multipliers of the sub-determinant alternate in sign. An easy way to remember is to look at the row and column numbers -- if they add up to an odd number, the sign should be -, otherwise it should be +. For example, the j entry is row 1, column 2. 1 + 2 = 3, which is odd, so the sign for the j multiplier should be -.
  3. Evaluating a 2x2 determinant is straightforward. ##\begin{vmatrix}a & b\\c & d\end{vmatrix} = ad - bc##
Likes topsquark and member 731016
It is a definition, not a derivation.
I guess you could say it depends as the definition for vector cross product is usually defined as
##A \times B = |A||B|sin(\theta) \hat{n} ##
where ##\theta## is the angle between them and ##\hat{n}## is a unit vector that is perpendicular to both A and B vectors.
https://en.wikipedia.org/wiki/Cross_product
EDIT: As @Mark44 points out in a later post, I forgot to mention that the resultant vector is perpendicular to both A and B vectors.
I learned the determinant method for memorizing the vector cross product, and it's always made it easy to remember how to calculate it. And if you're comfortable mentally wrapping around the diagonals, you don't need to write the extended determinant that is shown in the link below. Hope this helps.
https://efcms.engr.utk.edu/ef151-2019-01/pilot/classmgr.php?c=45&p=crossproduct
Thank you all (@jedishrfu , @pasmith, @Mark44, @malawi_glenn , @berkeman ) for your help!
I understand now, we had not done the determinant in class yet (still a couple of weeks away after the test!), but now I can easily remember it :)
Likes berkeman
Haha, we will test you in a few weeks!
Likes member 731016 and berkeman
##A \times B = |A||B|sin(\theta)## where ##\theta## is the angle between them
That isn't the formula for the cross product -- it's the magnitude of the cross product. IOW, for ##|A \times B|##. The wikipedia page gives this formula:
##a \times b = |a||b|sin(\theta) n##, where n is a unit vector perpendicular to both a and b.
Likes malawi_glenn, topsquark, jedishrfu and 1 other person
Homework Statement: I am trying to derive the formula
In a variant of your notation, I would write
##\vec {u} \times \vec {v} = \hat e_1(u_2v_3 - u_3v_2) + \hat e_2(u_3v_1 - u_1v_3) + \hat e_3(u_1v_2 - u_2v_1)##
Note the pattern...
123, 231, 312 (via cyclic permutations) are all even permutations of 123 ...and get the +
132, 321, 213 (via cyclic permutations) are all odd permutations of 123 ...and get the -
(Note this is seen in the post by @jedishrfu above,
as well as the posts by @Mark44 and
by @berkeman above. .. but keep the first factor in place in each term
(like what a simple computer would do to follow the pattern)
... don't rearrange (which would require more code for the computer to do).
The post by @pasmith has the most compact explanation.
I think the geometrical meaning should be kept in mind.
The cross-product is the oriented area of a parallelogram formed by the ordered pair of vetors ##(\vec u, \vec v)##.
In 3-dim, we can associate this area with a [pseudo]vector perpendicular to the plane, following the right-hand-rule. (In my opinion, the area feature is more important and more fundamental that the vector-via-the-right-hand-rule.)
Likes member 731016
Note the pattern...
Thank you for sharing that @robphy!
FAQ: Deriving algebraic definition of cross product
What is the cross product of two vectors?
The cross product of two vectors is a vector that is perpendicular to both of the original vectors. It is defined in three-dimensional space and results in a vector that is orthogonal to the plane formed by the original vectors.
How is the cross product of two vectors computed algebraically?
Algebraically, the cross product of two vectors a = (a1, a2, a3) and b = (b1, b2, b3) is computed using the determinant of a matrix:
| i   j   k  || a1  a2  a3 || b1  b2  b3 |
This results in the vector:
(a2*b3 - a3*b2, a3*b1 - a1*b3, a1*b2 - a2*b1)
Why is the cross product only defined in three-dimensional space?
The cross product is inherently a three-dimensional operation because it produces a vector that is orthogonal to the plane formed by the two input vectors. In higher dimensions, this concept does not generalize in the same way, and different operations are used to produce analogous results.
What are the properties of the cross product?
The cross product has several important properties:
  • Anticommutativity: a × b = -(b × a)
  • Distributivity: a × (b + c) = a × b + a × c
  • Scalar multiplication: (ca) × b = c(a × b) = a × (cb) for any scalar c.
  • Magnitude: The magnitude of the cross product a × b is |a| |b| sin(θ), where θ is the angle between a and b.
  • Orthogonality: The resulting vector is orthogonal to both a and b.
