Deriving an equation to find theta: Projectile motion
In summary, the question is asking for the launch angle for a projectile, which is determined by the speed and height at which it is launched. The equation to find the launch angle is Hmax=Vi^2sin^2(theta)/2G.
Mac5214
1. the question is this:
a projectile's speed at launch is four times its speed at the top of the trajectory. What is the launch angle?
I am given no numerical values, but from my understanding gravity is a constant 9.8, and at the maximum height velocity should be equal to 0. 2.the equation to find the maximum height is Hmax=Vi^2sin^2(theta)/2G and the equation for3. since the whole problem is diriving a equation i am lost as to where to start. other than knowing that the angle for maximum range is 45 degrees and that i can use the inverse of tan to find a angle of projection, but i am unsure how to find an angle that gives four times the initial speed. sorry if the question is sort of vague, it is all i was given. and thank you for any help you may provide.
You really need to list down all the kinematic equations. All of them. Then assess which ones are useful. Take those aside.
Then, think about what variables are changing and which are relevant.
In this case, you need to find how much time it takes for the projectile to reach the maximum height. It's good that you know how to derive that. But using that equation, plug that into the equation for speed at that point in time. I'm sure you should know what that is (even though it might take a little work).
Once you do that, you should be able to solve the rest.
Go through it slowly, we won't give you the answer, but we will make sure you're right along the way.
Have a go.
Welcome to the forum Matthiasc. There is a template for posts in the homework section.
Please list any other Relevant Equations you know and your attempt at a solution so we can see where you are getting stuck.
matthiasc said:
I am given no numerical values, but from my understanding gravity is a constant 9.8, and at the maximum height vertical velocity should be equal to 0.
In case you didn't spot it the question 1. asks about speed not velocity.
For question 1 you don't actually need the equations of motion, just trig. Perhaps make a sketch and mark the speeds and angle on it.
Okay so I may have got a answer, but I didn’t use any kinematic equations so I’m not sure if it is correct or not, I realized that the horizontal component of velocity is constant, so when the projectile is at the maximum height, the vertical component of velocity will be equal to 0 therefore you could pick out any number for the x component of velocity and multiply it by 4 for the y component , and then do the inverse cos of the x component divided by the y component to find theta? So for instance I did cos-1(1/4) and got a angle of 75.5. Is my logic wrong in any place?
Likes CWatters
No, it is irrelevant. Indeed, dimensional analysis shows the value of g must be irrelevant, so times and distances are not going to matter either.
Likes lekh2003 and CWatters
matthiasc said:
cos-1(1/4)
Well done.
Likes Mac5214
Your numerical answer is correct. To get ##cos(\theta)##, you need to divide the horizontal component by the hypotenuse, not the vertical component. Do you see why this is what you really did?
Likes haruspex
oh okay yes i do, its because cosine is the adjacent over the hypotenuse which is the total magnitude (4).
Thank you for helping me realize that.
Related to Deriving an equation to find theta: Projectile motion
1. What is projectile motion?
Projectile motion is the motion of an object through the air, under the influence of gravity, after it has been given an initial velocity. This type of motion follows a curved path known as a parabola.
2. Why is it important to derive an equation for theta in projectile motion?
Deriving an equation for theta in projectile motion allows us to calculate the angle at which an object should be launched in order to achieve a desired distance or height. This is crucial for activities such as sports, engineering, and even space exploration.
3. How can we derive an equation for theta in projectile motion?
The equation for theta can be derived by using the basic principles of projectile motion, such as the equations for displacement, velocity, and acceleration in the x and y directions. By manipulating these equations and using trigonometric identities, we can solve for theta.
4. What are the variables in the equation for theta in projectile motion?
The variables in the equation for theta include the initial velocity (v), the initial angle of launch (theta), the acceleration due to gravity (g), and the horizontal and vertical displacements (x and y, respectively).
5. Can the equation for theta be used for any projectile motion scenario?
Yes, the equation for theta can be used for any projectile motion scenario as long as the initial conditions (velocity, angle, and displacement) are known. However, it is important to note that this equation assumes a flat, non-rotating surface and neglects air resistance.
