I Deriving Contravariant Form of Levi-Civita Tensor
AndersF
TL;DR Summary
If the covariant form for the Levi-Civita is defined as ##\varepsilon_{i,j,k}:=\sqrt{g}\epsilon_{i,j,k}##, how could be shown from this definition that it's contravariant form is given by ##\varepsilon^{i,j,k}=\frac{1}{\sqrt{g}}\epsilon^{i,j,k}##?
The covariant form for the Levi-Civita is defined as ##\varepsilon_{i,j,k}:=\sqrt{g}\epsilon_{i,j,k}##. I want to show from this definition that it's contravariant form is given by ##\varepsilon^{i,j,k}=\frac{1}{\sqrt{g}}\epsilon^{i,j,k}##.My attemptWhat I have tried is to express this tensor ##\varepsilon^{i j k}## through the contraction with the metric tensor of ##\varepsilon_{i j k}## the contravariant form, and then to replace the definition of ##\varepsilon_{i j k}##:##\varepsilon^{i j k}=g^{i p} g^{j q} g^{k r} \varepsilon_{p q r}=g^{i p} g^{j q} g^{k r} \sqrt{g} \epsilon_{p q r}##
This expression reminds me of the the expression of the determinant of the dual metric tensor, ##g^{-1}=\det (g^{ij})##, through the Levi-Civita symbol:
##g^{-1}=g^{1 p} g^{2 q} g^{3 r} \epsilon_{p q r}##
But I'm stuck here, as I don't know how to match these expressions... Would there be any way to achieve this? Would this be a good way to prove the theorem?
I guess you talk about a 3D Riemannian manifold here. Then let's define ##\Delta_{jkl}=\Delta^{jkl}## as the totally antisymmetric symbol with ##\Delta_{123}=\Delta^{123}=1##.
Then
$$\epsilon_{jkl}=\sqrt{g} \Delta_{jkl} \quad \text{with} \quad g=\mathrm{det}(g_{\mu \nu})$$
are covariant (pseudo) tensor components.
Indeed, using the transformation law for covariant tensor components you get
$$\epsilon_{abc}'=\sqrt{g} \Delta_{jkl} \frac{\partial q^j}{\partial q^{\prime a}} \frac{\partial q^k}{\partial q^{\prime b}} \frac{\partial q^l}{\partial q^{\prime c}}=\sqrt{g} J \Delta_{abc},$$
where
$$J=\mathrm{det} (\partial_a' q^j)$$
is the Jacobian of the coordinate transformation.
On the other hand
$$g' = \mathrm{det} g_{ab}'=\mathrm{det} (\partial_a' q^j \partial_b' q^k g_{jk})=J^2 g.$$
So if ##J>0##, then indeed
$$\epsilon_{abc}'=\sqrt{g'} \Delta_{abc}.$$
If ##J<0## you get an additional minus sign. That's why ##\epsilon_{jkl}## are the components of a pseudo-tensor rather than a true tensor.
For the contravariant components you get
$$\epsilon^{jkl}=g^{ja} g^{kb} g^{lc} \epsilon_{abc} = \sqrt{g} g^{ja} g^{kb} g^{lc} \Delta_{abc} = \sqrt{g} \mathrm{det}(g^{ab}) \Delta^{jkl}=\frac{1}{g} \sqrt{g} \Delta^{jkl} = \frac{1}{\sqrt{g}} \Delta^{jkl},$$
where I've used that in a Riemannian manifold ##\mathrm{det}(g_{ab})>0##.
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
