Deriving differential equations for free rotation
In summary, the conversation was about formulating equations for the rotation of a body without external moments acting on its center of mass. The person decided to use the Euler equations, which resulted in a system of non-linear first-order differential equations. However, they were wondering how to obtain the specific set of equations requested. It was suggested to use a complex variable to solve the equations, which would result in the angular velocity rotating around the z axis and the total angular momentum being conserved. The conversation ended with a discussion about the purpose of finding these equations.
freddyfish
57
I was asked to formulate the equations governing the rotation of a body moving without any external moments acting about its centre of mass in terms of a coupled system of first order, nonlinear differential equations. I decided to go with the Euler equations, and I ended up with this:
\begin{equation} \label{symdif}
\begin{array}{l l l}
\dot{\omega}_x=\frac{I_{yy}-I_{zz}}{I_{xx}}\omega _y\omega _z\\
\dot{\omega}_y=\frac{I_{zz}-I_{xx}}{I_{yy}}\omega _z\omega _x\\
\dot{\omega}_z=\frac{I_{xx}-I_{yy}}{I_{zz}}\omega _x\omega _y
\end{array}
\end{equation}
\begin{equation}
(I_{xx}=I_{yy}<I_{zz})
\end{equation}
This indicates that $$\omega_z=constant$$which makes it possible to solve the system of differential equations, but I wonder how one would end up with the differential equations explicitly asked for.
I guess you look for the solution of the differential equation. Since [itex]\omega_z=\text{const}[/itex] we can indeed solve the remaining system of two coupled linear differential equations. To make it a bit less tedious to write we set
[tex]\Omega=\frac{I_{zz}-I_{xx}}{I_{yy}} \omega_z.[/tex]
Since for a symmetric top [itex]I_{xx}=I_{yy}[/itex] the system reads
[tex]\dot{\omega}_x=-\Omega \omega_y, \quad \dot{\omega}_y=\Omega \omega_x.[/tex]
To solve this equation, you can either use matrix-exponential functions or, much simpler in this case, the trick to introduce a complex variable
[tex]u=\omega_x+\mathrm{i} \omega_y.[/tex]
Then from the equations of motion you get
[tex]\dot{u}=\Omega (-\omega_y+\mathrm{i} \omega_x)=\mathrm{i} \Omega (\omega_x+\mathrm{i} \omega_y)=\mathrm{i} \Omega u.[/tex]
The general solution is immediately given by
[tex]u(x)=u_0 \exp(\mathrm{i} \Omega t)[/tex]
with [itex]u_0[/itex] integration constants fixed by the initial conditions [itex]\omega_x(0)=\omega_{x0}[/itex], [itex]\omega_y(0)=\omega_{y0}[/itex]. To get the angular velocities you only have to take real and imaginary part of our solution with
[tex]u_0=\omega_{x0}+\mathrm{i} \omega_{y0}[/tex]
leading to
[tex]\omega_x(t)=\omega_{x0} \cos(\Omega t)-\omega_{y0} \sin(\Omega t),[/tex]
[tex]\omega_y(t)=\omega_{y0} \cos(\Omega t)+\omega_{x0} \sin(\Omega t).[/tex]
That tells you that the angular velocity rotates around the [itex]z[/itex] axis sweeping out the polhode cone (seen from the reference frame fixed with the spinning body, where the above Euler equations hold).
Seen from the inertial frame, of course the total angular momentum is conserved, defining a fixed axis, around which both the angular velocity (sweeping out the herpole cone) and the symmetry axis of the body (sweeping out the nutation cone) rotate.
Hey
No, I am unfortunately not looking for the answer to the equations.
I am asked to come up with a specific set of differential equations to later apply to a dynamic system, where the latter is not of any interest for the moment. However, the equations I derived are not nonlinear, and in that sense better than the equations asked for. My question was about what equations the latter would be and being a common subject in mechanics I was hoping that someone had a quick answer lying around, since deriving them would just be a waste of effort forasmuch as I already have calculated the angular velocity.
I don't understand what you have to do. What is the precise question asked?
The Euler equations are, of course non-linear first-order differential equations. Only for the symmetric case they effectively simplify to the linear one as discussed.
Your approach of using the Euler equations to derive the differential equations for free rotation is a valid and commonly used method. The Euler equations describe the motion of a rigid body rotating around its center of mass in a non-inertial reference frame. By setting the external moments to zero, you are effectively considering a body with no external forces acting on it, which results in free rotation.
To address your question about explicitly deriving the differential equations, it is important to understand the concept of coupled systems of equations. In this case, the three equations in your system are coupled because each variable $\omega_x$, $\omega_y$, and $\omega_z$ appears in all three equations. This means that the motion of the body in one direction is influenced by its motion in the other two directions.
To explicitly derive the differential equations for free rotation, you would need to start with the equations of motion for a rigid body in a non-inertial reference frame, which includes the effects of rotation and translation. From there, you would need to set the external forces and moments to zero and simplify the equations to obtain the three coupled differential equations shown in your solution.
In summary, your use of the Euler equations is a valid approach to deriving the differential equations for free rotation. However, for a more explicit derivation, one would need to start with the equations of motion for a rigid body and simplify them to obtain the desired equations.
Related to Deriving differential equations for free rotation
1. What is the definition of free rotation?
Free rotation refers to a type of motion in which an object is able to rotate freely without being constrained by external forces or torques.
2. How are differential equations used in free rotation?
Differential equations are used to mathematically describe the motion of a rotating object by relating its position, velocity, and acceleration at any given moment in time.
3. What are the basic principles behind deriving differential equations for free rotation?
The basic principles involve applying Newton's laws of motion and the laws of rotational motion, such as the moment of inertia and angular momentum, to create a set of equations that describe the rotational motion of an object.
4. What variables are typically used in the differential equations for free rotation?
The variables used may include the angular position, velocity, and acceleration of the object, as well as parameters such as the moment of inertia and the applied torque.
5. What are some real-world applications of differential equations for free rotation?
Differential equations for free rotation have many practical applications, such as in the design and analysis of rotating machinery, gyroscopes, and celestial bodies in space. They are also used in physics and engineering research to better understand the behavior of rotating systems.
