Deriving electric field with given potential
In summary: I'm sorry, I'm really having trouble understanding what you are asking. Please clarify your question. In summary, we are given the equations for dipole potential and electric field and asked to show that the electric field is equal to the negative gradient of the potential. After attempting a solution, the question arises as to why only one term is multiplied by r^hat when using the nabla operator. Through further discussion, it is determined that the nabla operator should be used in Cartesian coordinates and the potential should be written out in terms of x,
AndrewAmmerlaa
Given that the potential of dipole is equal to:
[tex]V(\vec{r})=\frac{\vec{p}\vec{r}}{4\pi\epsilon_0 r^3}[/tex]
show that the electric field is equal to:
[tex]\vec{E}(\vec{r})=\frac{1}{4\pi\epsilon_0}(\frac{3(\vec{p}\vec{r})\vec{r}}{r^5}-\frac{\vec{p}}{r^3})[/tex]
[tex]\vec{E}(\vec{r})=-\nabla V(\vec{r})[/tex]
I thought i could just differentiate V(r):
[tex]\vec{E}(\vec{r})=-\nabla V(\vec{r}) = \frac{-1}{4\pi\epsilon_0}(\frac{r^3\vec{p}-3r^2\vec{p}\vec{r}}{r^6})\hat{r}=\frac{1}{4\pi\epsilon_0}(\frac{3(\vec{p}\vec{r})\vec{r}}{r^5}-\frac{\vec{p}\vec{r}}{r^4})[/tex]
but that's not the correct answer, my question is: why does only one of the terms get multiplied with r^hat? It seems to me that the nabla operator would multiply the whole thing with r^hat, but that's not the correct answer according to the question (I checked if the question is correct and it is)
AndrewAmmerlaa said:
but that's not the correct answer, my question is: why does only one of the terms get multiplied with r^hat? It seems to me that the nabla operator would multiply the whole thing with r^hat, but that's not the correct answer according to the question (I checked if the question is correct and it is)[/code]
use correct form of Nabla operator .
V(⃗r)=⃗p⃗r4πϵ0r3V(r→)=p→r→4πϵ0r3
in your expression for potential there is there should be p.r .
I used this, is this not the correct form?
[tex]\nabla f=\frac{\partial f}{\partial r}\hat{r}+\frac{1}{r}\frac{\partial f}{\partial \theta}\hat{\theta}+\frac{1}{rsin{\theta}}\frac{\partial f}{\partial \phi}\hat{\phi}[/tex]
V is not dependent on phi or theta so the derivative of that is zero, that just leaves that partial derivative to r times r^hat
dipole potential has a standard form -one can see in any textbook
V(r,theta)= p.r/ 4Pi.epsilon.r^2 so check in the question !
V can depend on phi and theta through the product of the position vector ##\vec r ## with the vector ##\vec p##. For example, if ##\vec p## is parallel with the z axis, ##\vec p\cdot \vec r = pr\cos(\theta)##Only a spherically symmetric potential depends only on r.
Use the form of the nabla operator in Cartesian coordinates. What is it?
If you check your result for the electric field you can see that one term is a vector, the other is a scalar, which is certainly wrong.
ehild said:
V can depend on phi and theta through the position vector ##\vec r ##. Only a spherically symmetric potential depends only on r.
I hadn't thought of that, adding the derivative of V to theta gives an term with ##\hat{\theta}## and i have no idea what to do with that.
nabla in cartesian coordinates:
[tex]\nabla f= \frac{\partial f}{\partial x}\hat{x}+\frac{\partial f}{\partial y}\hat{y}+\frac{\partial f}{\partial z}\hat{z}[/tex]
but that gives me this:
[tex]
\vec{E}(\vec{r})=-\nabla \frac{\vec{p}\vec{r}}{4\pi\epsilon_0 r^3}=-\frac{r^3\vec{p}-3r^2\vec{p}\vec{r}}{r^6}\hat{x}-\frac{r^3\vec{p}-3r^2\vec{p}\vec{r}}{r^6}\hat{y}-\frac{r^3\vec{p}-3r^2\vec{p}\vec{r}}{r^6}\hat{z}=\frac{1}{4\pi\epsilon_0}(\frac{3\vec{p}\vec{r}}{r^4}-\frac{\vec{p}}{r^3})(\hat{x}+\hat{y}+\hat{z}) [/tex] but that leaves me one ##\vec r ## short in the first term, and ##\hat{x}+\hat{y}+\hat{z}## would be the vector (1,1,1) and I'm unsure what to do with that.
[tex]
That is wrong. Write out the whole potential in Cartesian coordinates, and take the partial derivatives with respect x, y, z.
Ok, so I got this:
[tex]
V(\vec{r})=V(x,y,z)=\frac{1}{4\pi\epsilon_0(x^2+y^2+z^2)^{\frac{3}{2}}}\begin{pmatrix}p_1 \\ p_2 \\ p_3 \end{pmatrix} \begin{pmatrix} x \\ y \\ z \end{pmatrix}=\frac{p_1x+p_2y+p_3z}{4\pi\epsilon_0(x^2+y^2+z^2)^{\frac{3}{2}}}
\implies
\vec{E}(\vec{r})=\frac{-1}{4\pi\epsilon_0}(\frac{\sqrt{x^2+y^2+z^2}^3p_1-3x\sqrt{x^2+y^2+z^2}p_1x}{\sqrt{x^2+y^2+z^2}^6}\hat{x}[/tex]
plus simular terms for y and z
[tex]
=\frac{1}{4\pi\epsilon_0}(\frac{3(p_1x^2\hat{x}+p_2y^2\hat{y}+p_3z^2\hat{z})}{\sqrt{x^2+y^2+z^2}^5}-\frac{p_1\hat{x}+p_2\hat{y}+p_3\hat{z}}{\sqrt{x^2+y^2+z^2}^3}=\frac{1}{4\pi\epsilon_0}(\frac{3(p_1x^2\hat{x}+p_2y^2\hat{y}\hat{x}+p_3z^2\hat{z})}{r^5}-\frac{p_1\hat{x}+p_2\hat{y}+p_3\hat{z}}{r^3})
[/tex]
how do I turn the p1+p2+p3 back into a vector? I'm sorry I'm asking so many questions i thought i understood vector calculus but it turns out i don't.
EDIT: never mind, i forgot the hats, that makes adding p1 p2 and p3 easy, but what about the p1x^2+p2y^2+p3z^2?
wouldn't that be something like this:
[tex]
\begin{pmatrix}
p_1x^2\\
p_2y^2\\
p_3z^2\\
\end{pmatrix}
[/tex] instead of ##(\vec{p}\vec{r})\vec{r}##
Ok, so I got this:
[tex]
\implies
You made a mistake. When you take the derivative of the denominator, you have to keep the whole numerator.
I got it:
[tex]
\implies
\vec{E}(\vec{r})=\frac{-1}{4\pi\epsilon_0}(\frac{\sqrt{x^2+y^2+z^2}^3p_1-3x\sqrt{x^2+y^2+z^2}(p_1x+p_2y+p_3z)}{\sqrt{x^2+y^2+z^2}^6}\hat{x}[/tex]
[tex]
=\frac{1}{4\pi\epsilon_0}(\frac{3x(p_1x+p_2y+p_3z)\hat{x}+3y(p_1x+p_2y+p_3z)\hat{y}+3z(p_1x+p_2y+p_3z)\hat{z}}{\sqrt{x^2+y^2+z^2}^5}-\frac{p_1\hat{x}+p_2\hat{y}+p_3\hat{z}}{\sqrt{x^2+y^2+z^2}^3}=\frac{1}{4\pi\epsilon_0}(\frac{3x\vec{p}\vec{r}\hat{x}+3y\vec{p}\vec{r}\hat{y}+3z\vec{p}\vec{r}\hat{z}}{r^5}-\frac{p_1\hat{x}+p_2\hat{y}+p_3\hat{z}}{r^3})=
\frac{1}{4\pi\epsilon_0}(\frac{3\vec{p}\vec{r}\vec{r}}{r^5}-\frac{\vec{p}}{r^3})
[/tex]
Thanks so much, this was a tough one.
I got it:
[tex]
[/tex]
Correctly:
[tex]
[/tex]
There is a simpler way to find the gradient: It can be considered as derivative with respect ##\vec r ##.
r is the magnitude of ##\vec r## so ##r=\sqrt{{\vec r}^2}##
[tex]V(\vec{r})=\frac{\vec p \cdot \vec r }{4\pi\epsilon_0 r^3}=\frac{1}{4\pi\epsilon_0}\frac{\vec p \cdot \vec r }{\left( {\vec r}^2\right)^{3/2}}[/tex]
[tex]\vec E = - \frac{dV}{d \vec r }=- \frac{1}{4\pi\epsilon_0}\frac{\vec p \left( {\vec r}^2\right)^{3/2} -(\vec p \cdot \vec r)3(\vec r^2)^{1/2} \vec r}{\left( {\vec r}^2\right)^{3/2}}=-\frac{1}{4\pi\epsilon_0}\frac{\vec p r^3 -3(\vec p \cdot \vec r)r \vec r}{r^6}[/tex]
FAQ: Deriving electric field with given potential
How is electric field derived from given potential?
Electric field is derived from given potential by taking the negative gradient of the potential function. This means that the electric field at any point is equal to the negative of the rate of change of potential with respect to distance in each direction.
Can any potential function be used to derive electric field?
Yes, any potential function can be used to derive electric field as long as it satisfies the Laplace's equation, which describes the relationship between potential and electric field.
What is the mathematical formula for deriving electric field from potential?
The mathematical formula for deriving electric field from potential is: E = -∇V, where E is the electric field, V is the potential function, and ∇ is the gradient operator.
What are the units for electric field and potential?
The units for electric field are Newtons per Coulomb (N/C) and the units for potential are Joules per Coulomb (J/C), also known as Volts (V).
Can electric field be derived in three dimensions?
Yes, electric field can be derived in three dimensions by taking the partial derivatives of the potential function with respect to each coordinate axis (x, y, and z).
