dE_logics
- 742
Consider 2 magnetic masses, m1 and m2; these 2 repel each other for a distance s with force f (relative to each other)...which applies from m1 to m2.
Predict final velocity of m1 and m2.
Assume final distance to be v1 and v2
Assume the 2 masses at rest initially.
Take any values pointing to the direction of motion of m1 as positive; that is the final velocity of m1 will be positive and m2 will be negative.
So the f by the above definition will be negative (when real world values are taken).
2as = v^2 - u^2; this might be used...I used it
Using standard formula 2as = v^2 – u^2
Its to be noted that the formula is applicable only when the formula from where the normal reaction is derived is stationary with respect to the frame of the observer, so the distance df that the body and mass covers is partially due to the distance traveled by m1 and partially due to the the distance that the body travels (this will be observed by the observer).
So the actual distance that the mass travels (while accelerating) is d1, and that for the body is d2 (new variables assumed, we do not know this value), however the sum of d1 and d2 is equal to the total distance traveled will be equal to the distance for which the force applies (s).
Also the distance traveled by each the mass and the body is an inverse and direct function of mass.
Here a1 (acceleration on m1) = -f/m1
a2 (acceleration on m2) = f/m2
By 2as = v^2 – u^2 -
2*a2*d2 = v2^2...1
2*a1*d1 = v1^2...2
-d2 + d1 = s...3 (this is done cause the real value of d2 will be negative, following the coordinate system)
d1/d2 = m2/m1...4 (as stated before, distance traveled is a direct and inverse function of mass).
There are 4 equation and 4 unknown.
Since the formula needs to be derived, they cannot be solved simultaneously.
Making d2 the subject from equation 4 -
(d1*m1)/m2 = d2
Substituting in equation 3 -
-((d1*m1)/m2) + d1 = s
-d1((m1)/m2) - 1) = s
-d1((m1-m2)/m2) = s
d1 = -s*m2/(m1-m2)
Substituting above value of d1 in equation 2 -
2*a1*(-s*m2/(m1-m2)) = v1^2
From equation 4 making d1 the subject -
d1 = (d2*m2)/m1
Substituting value of d1 in equation 3 -
-d2 + ((d2*m2)/m1) = s
-d2(1 - (m2)/m1) = s
-d2((m1-m2)/m1) = s
d2 = (-s*m1)/(m1-m2)
Substituting value of d2 in equation 1
2*a2*((-s*m1)/(m1-m2)) = v2^2
Final equations -
and
Putting real world values – f = -3000
m1 = 610
m2 = 10
s = 2
a2 = -300
a1 = 300/61
v2^2 = 1220....ok
v1^2 = -20/61.....the negativity needs to be removed
Squaring v1^2 = -20/61 (is then step OK?)
v1^4 = 400/3721.....ok
