I Deriving formula for kinetic energy
The discussion focuses on deriving the formula for kinetic energy, specifically the expression \( \frac{1}{2}mv^2 \), from given assumptions in classical physics. The user starts with the equations \( \ddot{z} = 0 \) and \( m\ddot{\textbf{r}} \cdot \dot{\textbf{r}} = 0 \), leading to the conclusion that kinetic energy is constant when no work is done. A constant applied force implies that acceleration and velocity maintain a consistent direction, allowing for the manipulation of the equations. The conversation emphasizes the relationship between the time derivative of kinetic energy and the conditions under which it remains unchanged. Ultimately, the thread seeks clarification on completing the derivation under these assumptions.
billard
TL;DR Summary
Issue deriving 1/2 *mv^2 from some pre-assumed equations
Hello! I am new to the differential version of classical physics, and I am trying to work how to derive kinetic energy from some pre-assumed equations:
Assume that we know: ##\ddot{z} = 0## and ##m\ddot{\textbf{r}} \cdot \dot{\textbf{r}} = 0##This results in $$\frac{1}{2}m\dot{r}^2 = W = const.$$
How is the kinetic energy given here with our pre-assumptions? I am sure this is very simple, forgive me, I am a beginner.
Work done per time is innerproduct of Force F and velocity v. F =ma. When no work done, you can deduce that KE is conserved.
billard said:
TL;DR Summary: Issue deriving 1/2 *mv^2 from some pre-assumed equations
If the applied force is constant, then ##\ddot{\textbf{r}}## is constant, and in particular, so is the direction of ##\dot{\textbf{r}}##, ala Newton's 2nd.
So
##\ddot{\textbf{r}} \cdot \dot{\textbf{r}} = \ddot{r} \dot{r} \, cos( \theta )##
where ##\theta## is the angle between the acceleration and the velocity is constant.
So now you have
##m\ddot{r} \dot{r} cos( \theta ) = ( m \, cos( \theta ) ) \ddot{r} \dot{r} = 0##
Now note that
##\dfrac{d}{dt} ( \dot{r} )^2 = 2 \ddot{r} \dot{r}##
Can you finish?
-Dan
Likes exponent137
Start with ##K=\frac{1}{2}m(\mathbf{\dot r}\cdot \mathbf{\dot r}).##
Can you show that ##\dfrac{dK}{dt}=0~## if ##~\mathbf{\dot r}\cdot \mathbf{\ddot r}=0~?##
Here assume that ##\mathbf{r}=x~\mathbf{\hat x}+y~\mathbf{\hat y}+z~\mathbf{\hat z}.##
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
